A beginner's learning curve
/ A beginner's learning curve #1
Trev
Platinum Member
Williamson, NY (near Rochester)
Currently tractor-less
A beginner\'s learning curve
I was helping a buddy move a few tons of top soil the other day, using my rear dirt scoop, and I had a good learning experience. Normally, I set my engine speed with the hand throttle, and then do my work. What I found during this job is that it's much more effective to set the hand throttle to a medium-slow idle, and then use the foot throttle for most of my work. For example, I could pick up a load of dirt, move forward by easing the clutch out at low RPM so no dirt fell off the back, then accelerate, upshift just as you would in a car, etc., all using the foot throttle. Worked much better!
I know.. you guys with the HSTs are probably snickering /w3tcompact/icons/laugh.gif but this was a helpful discovery for me with my SyncReverser John Deere 4300.
Just a thought for the other beginners here.. and I know there are lots of us. /w3tcompact/icons/wink.gif
Best,
Bob
/ A beginner's learning curve #2
Re: A beginner\'s learning curve
I do this with loader work on the 1050. In fact, I use the foot throttle for everything except pto work and roading.
/ A beginner's learning curve #3
Only kidding. I have 60 hours in total and a learn something everyday I use it. Great stuff this tractoring. With or without HST.
GS
/ A beginner's learning curve #4
That is a very good tool Trev. You can go significantly up and down in speed just with the foot feed.
<font color=blue>That is a very good tool Trev. You can go significantly up and down in speed just with the foot feed. </font color=blue>
Is it any harder on a diesel to be changing speed routinely, as opposed to just setting it to an appropriate speed and leaving it there?
/ A beginner's learning curve #6
Bob,
It might be a little bit more wear on the engine to vary speed after the break-in period (you want to vary the speed during the break-in).
Using the over the road tractors as an example just how many million miles do you want to get on the engine? :) The road diesels do lots of varying of rpm's going cross country.
Don
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
LEEBOY 8510C ASPHALT PAVER (A64279)
LEEBOY 8510C...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
