99 S10 ABS problem
/ 99 S10 ABS problem #1
gugy
Upstate New York/Holbrook L.I.
BX 22
I have a '99 S10 that the ABS comes on at low speed stop.No codes in the ABS system and no idiot lights on dash. The pickup has fairly new front hub/ bearings which come with brake sensors. I changed the top portion of the brake controler and still have the problem.I know its the ABS because when I pull the fuse the problem goes away but Naturally I get an ABS warning light on the dash.Any help would be appreciated
Thank You
Bob
/ 99 S10 ABS problem #2
You need to clean off the wheel speed sensors - hopefully not replace them. GM had problems here in the Midwest "salt belt" that led to a recall - but i don't know if that covers New York. It was only a regional recall. I would talk to a Dealer and see what they will do for you. Hope this helps.
/ 99 S10 ABS problem #3
we have a 99 suburban that had problems with the abs- failed at low speeds. It was NOT covered under the recall. My mechanic told me he clean the sensors and hopefully it would fix the problem- but he may break them while cleaning- a $60.00 per side job could go to $600.00- and he did not know which side was faulty. I pulled the fuse and drove with out ABS for a while. We had a bearing fail and it ended up to be the culprit. I've had two other trucks ( ford and gm ) that gave ABS failure lights when the bearings went.
strange that you are not getting an indicator light?
I want to thank you guys for the reply.I still can't fix my problem.
Both front sensors are clean,I called the Chevy dealer and they checked with my vin number for a recall. No such luck.I guess I'm going to have to bypass the ABS by removing the fuse.
Once again thank you.
Bob
/ 99 S10 ABS problem #5
You might check the speed sensor in the rear differential , if you haven't already
2022 EZ-GO ELITE...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2012 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2012 VOLVO VNL 6X4...
400 lb Electric Hoist (A66408)
400 lb Electric...
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
(4) 12-16.5 Tires (A65640)
(4) 12-16.5 Tires...
