'97 f150 4.2L engine wiring
/ '97 f150 4.2L engine wiring #1
bjr
Veteran Member
Eastern WA
Jinma JM354
I'm needing to be able to test run this engine on a test stand that I'll build. What's needed as far as electrical components? I'm not great on all the acronyms for the components, so just say what they are. I want to make sure there's no oil leak or fuel leaks and oil pressure before I stick the engine (used wrecking yard engine) in as it's a lot of work getting it out. I'll hook up the radiator and want to run the engine enough to bring it up to operating temperature. Thanks in advance. bjr
