955 radiator
/ 955 radiator #1
Molerj
Platinum Member
Eastern Ohio
JD 955, 1978 Economy Power King, JD X500
Anyone know of an aftermarket radiator to replace the JD 108901? JD price is 391.69.
/ 955 radiator #2
Have you asked at a rad shop to see how much it would cost to replace the core? I tried Googling the part number but didn't have much success with prices.
/ 955 radiator
I did and it was more than a new radiator!
/ 955 radiator
Had to suck it up and buy a new one. 414.00 delivered. Ouch!
/ 955 radiator #5
What happened with the old one? Battery acid, stick? Just curious...
/ 955 radiator
Was cleaning it off after mowing for several hrs. and noticed an oil leak from the oil cooler. One of the short lines was cracked. Replaced the oil cooler and was checking for leaks and then noticed antifreeze. I pressure washed the radiator so I'm sure that exposed the rotten core. It would have started leaking soon anyway. Btw, there are two small tabs that the oil cooler is bolted to on the radiator. One of mine broke so I would attribute the cracked line to the vibration.
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
CAT R500/D9R Ripper Teeth (8) (A68134)
CAT R500/D9R...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
