955 radiator
/ 955 radiator #1
Molerj
Platinum Member
Eastern Ohio
JD 955, 1978 Economy Power King, JD X500
Anyone know of an aftermarket radiator to replace the JD 108901? JD price is 391.69.
/ 955 radiator #2
Have you asked at a rad shop to see how much it would cost to replace the core? I tried Googling the part number but didn't have much success with prices.
/ 955 radiator
I did and it was more than a new radiator!
/ 955 radiator
Had to suck it up and buy a new one. 414.00 delivered. Ouch!
/ 955 radiator #5
What happened with the old one? Battery acid, stick? Just curious...
/ 955 radiator
Was cleaning it off after mowing for several hrs. and noticed an oil leak from the oil cooler. One of the short lines was cracked. Replaced the oil cooler and was checking for leaks and then noticed antifreeze. I pressure washed the radiator so I'm sure that exposed the rotten core. It would have started leaking soon anyway. Btw, there are two small tabs that the oil cooler is bolted to on the radiator. One of mine broke so I would attribute the cracked line to the vibration.
2019 RAM LARAMIE 1500 (A67714)
2019 RAM LARAMIE...
PALLET OF MISC ITEMS (A68842)
PALLET OF MISC...
(2) Goodyear 12.5/80-18 Tires (A64911)
(2) Goodyear...
2019 CATERPILLAR 315FL CR EXCAVATOR (A65056)
2019 CATERPILLAR...
PALLET OF HYD HOSES (A68842)
PALLET OF HYD...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
