917 flail mower
/ 917 flail mower #1
Oh henry
2638 mahindra
Hello I just got a 917 flail mower it has 3 rows of 14 corse cut knifes it is out of balance does. There's multiple holes for mounting does anyone have info how to put it back correctly? I am not sure if it's corse cut or fine cut mower
Thanks
Mike Henry
/ 917 flail mower #2
It is a course cut mower and can use fine cut blades. I can take a picture of mine tomorrow
/ 917 flail mower #3
Here are some pictures of my 71" mower
/ 917 flail mower
Awesome thanks
/ 917 flail mower
Hey my next question is the drive pulley is there anything specific on getting it off I noticed last night the drive pulley is off not in line with the rest of the drive system it cruves out I need to see about getting that aligned.
Thanks
/ 917 flail mower #6
If I remember right, it is on a tapered, keyed shaft. A good puller will get it off.
/ 917 flail mower
Awesome thanks not sure if it can be pushed back but going to try
/ 917 flail mower #8
The pulley is not loose? You need to take it off and see what shape the key and shaft are in to see why it has come out like that.
And, just to be clear, it is the bottom pulley for the rotor that has come out, not the top drive pulley.
/ 917 flail mower
Update i took the blades off still has vibration. I pulled the bottom pulley off it looked fine the whole cutter shaft slides back and forth.both bearings looks good.going to order new ones. I am stumped lol I'll also take it to drive shaft shop to have it balanced. My question is what keeps the shaft from sliding back and forth am I missing something?
/ 917 flail mower #10
The bearings on the rotor have locking collars to keep it from walking back and forth.
Are there a stack of weights bolted on the inside end of the rotor?
/ 917 flail mower
Yes there is a stack of weights. That one collor with the set screw was against the pulley.
/ 917 flail mower #12
Are you sure the rotor is not bent?
Also, we're the collars locked to the bearings?
/ 917 flail mower
No collor was on the right side. On the drive side the collar was locked against the pulley kinda like someone just thew it together. I ordered another collor. As far as the cutter being bent I haven't seen anything wrong once I get the new berings I'll get the drive shaft shop to look at it
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2022 EZ-GO ELITE...
Hydraulic Pump (A65640)
Hydraulic Pump...
