8N restored with pics
   / 8N restored with pics
Those are just bars to keep the three point lower arm’s from moving up or down to keep the draw bar in a fixed position.
We always used them to pull our hay rake.
Getting a center draw bar that mounts below the PTO / rear axle eliminates the need for those bars.
I've never encountered them before but it makes sense. There's been a few times I would have liked the 3 pt to stay down. Never thought of doing something like that.
   / 8N restored with pics #42
If you ever have it in your pickup, post a pic! What do you use for ramps? That must feel sketchy loading and unloading, LOL
For ramps, I cut a couple of 12” x 2” tongue and groove white oak barn floor planks to 8 ft long. I trimmed 4” x 3” sawed white oak rafter sections, and nailed them to the underside of the planks for added strength.
I recovered that wood from a couple old 36’ x 46’ x 16’ post and beam barns that my great great grandad built in 1881 & 1883. I dismantled those because the roofs and foundations were failing and to make room for a new pole-barn.
The 8 ft box of my 2000 Silverado fit that Cub like a glove. To tie it down, I used (2) 2” ratchet straps, anchored to the built in anchor points inside the (4) lower corners of the truck box.
I don’t believe that it is “just a coincidence” that the standard Cub fits so well in a regular full sized pickup truck box. Most likely, that was the design criteria used, back in the 1940’s, when that tractor was developed.
Of course this won’t work with a Farmall Super A, or with the more popular short boxes that most folks get on their pickup trucks these days.
As far as the truck handling with the tractor in back, it was very good. Less sway in the corners than when I have my 8 ft camper on back. I can’t stand trailers, so I am really appreciating the Cub.
I have a decent spot to load/unload at home, shown there on the picture at the back of the stone driveway area behind my pole barn. There is an even better spot over at my parents place, 20 miles away. They have a sand filter septic system on their front yard. I back up to that, and there is very little angle needed on the ramps to get the tractor on and off.
To load up the tractor, I remove the truck tailgate and rear the end of the ramps on the rear step bumper. The Cub’s front tire width is adjusted to less than 4 ft, while the rears are at 4’ - 6”. That wider rear setting gives the tractor more stability but prevents me from being able to close the tailgate. If I moved them into the narrowest (4) ft position, I could pull the tractor another 1-1/2” forward, and close the tailgate with it inside.
I just left the tailgate at home (I had to remove it to use the ramps anyhow), when I hauled the tractor over to my parents place, to do a (3) hour job.
   / 8N restored with pics #43
To load up he tractor, I remove the truck tailgate and rear the end of the ramps on the rear step bumper. The Cub’s front tire width is adjusted to less than 4 ft, while the rears are at 4’ - 6”. That wider rear setting gives the tractor more stability but prevents me from being able to close the tailgate. If I moved them into the narrowest (4) ft position, I could pull the tractor another 1-1/2” forward, and close the tailgate with it inside.
You don't DRIVE it up there, I assume. That would scare the tar out of me. I've seen too many videos of flip overs...
A winch of some sort?
I like those old Fords. I may (probably will) get another. Before and after of my 9N "resto" pics:
   / 8N restored with pics #44
Drive on, drive off. I even did it a few times with my 4 x 4 truck, which sits about 4” higher. No sweat at all with this 2wd backed up to a high spot. Easier than driving on and off a trailer on level ground.
Nice 9n. Some day, after I retire and gain a little extra time to care for them, I’d like to get one of those. What year is that one ?
   / 8N restored with pics #46
That is cool! Thanks for sharing. I like it!
You must get some looks going down the road with that eh? LOL
   / 8N restored with pics #47
Very nice! Do you or someone else have that for sale now? I just saw one identical with the discs for sale in the Ford section of Marketbook (Canadian version of Tractorhouse)
   / 8N restored with pics #48
I was getting some attention from across the road while I was unloading at my parent’s place. There is a busy chainsaw/lawnmower sales and service shop over there.
A little bit of research development went into the wood ramp design. First, I cut the 142 year old 2” x 12” white oak planks 12 ft long, to keep the loading angle lower, and I did not have the under center reinforcement beam.
One of the 12 footers snapped near the center when I was half way up:
No trouble after I cut the length down to 8 ft and added the bottom reinforcement beams.
One of the other keys to safe loading and unloading with the 2wd pickup, is having a “high, dry, flat” spot to back the truck up to. With my 4wd truck, I could back up into almost any roadside ditch, and sometimes not even need the ramps, driving right up on the tailgate.
As I mentioned earlier, the stone pad behind my pole barn works well for that here at home. The raised front yard sand filter area works even better over at my parents.
   / 8N restored with pics #49
Wow! You got some STONES brother. :ROFLMAO: That broken board is what scares me. I was puckered just driving my zero-turn mower onto a trailer when I bought it.
   / 8N restored with pics #50
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A56435)
2003 International...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
