Backhoe 8B backhoe hyd cylinder
/ 8B backhoe hyd cylinder #1
kidbuffalo
Caneadea,N.Y.
JD 970
Any one know what size hydraulic cylinder on the 8B backhoe ? I need to repair or replace the dipper cylinder. I think all 3 on the hoe are the same size. I'm going to give the JD dealer a call and inquire about one. I will also call the local hyd. cylinder repair shop. I just don't want to get killed on the cost
/ 8B backhoe hyd cylinder #2
don't know the sizes, but the lift and dipstick are the same cylinder, bucket is a different number, from Deere about $1500.00, packing kits $120-150, highly suggest pulling it and taking to local repair shop so they can work you up a quote
/ 8B backhoe hyd cylinder #3
Don't know either, but most hydraulic shops can do it for reasonable cost. Also unless there need something special, most can be rebuilt by your self, I've done several
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
LMC Ag 400 Gal Front Mounted Tank (A64119)
LMC Ag 400 Gal...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
