Oil & Fuel 855 fuel solenoid
/ 855 fuel solenoid #1
techwrtr2
Platinum Member
Alabama PA
Which one?
Having an issue with my 855. My research here leads me to think it's related to the fuel solenoid, but before I start tearing things apart I thought I'd check in with those who know more about this thing than I do.
Under normal conditions, the 855 starts easily even in very cold weather. But I've had an intermittent issue that began during the fall when it had to spend several days parked outside in the rain.
When the problem occurs, the tractor cranks longer before it fires. When it does fire, it's running at a very low speed and very rough. At full throttle it's not even at a normal idle speed, under 1000RPM. Lots of black smoke too. Pulling the throttle back to the idle position will shut the tractor off.
I've also noticed when it's doing this, I can turn the key to off and it'll just keep on sputtering.
Usually when it misbehaves, once it starts I"ll run push it to full throttle, pause long enough to turn the key to off and then slam the throttle to idle. Most of the time on the next try it'll fire up and I can go play. Took two tries on Saturday. Problem seems to be getting more frequent.
As stated, from what I've read here I wonder if the solenoid is the issue, I'm hoping when I tear into it I'll find it's nothing more than some poor connections.
I just use it too much to run off on wild goose chases looking for problems that don't exist. :D
/ 855 fuel solenoid #2
I think the fuel solenoid is either open or closed. If it is open, the engine will run and if it is closed, it won't. Your situation sounds like something else to me.
Are your fuel and air filters clean? I had an air leak in the fuel filter housing gasket that didn't leak fuel out but sucked air in. It made it hard to impossible to start and was hard to find (hint - the glass fuel bowl was less than full).
/ 855 fuel solenoid
I think I see where you are coming from... while I'm sure the fuel filter is good to go, it's on my agenda for replacment. This problem however is not a consant thing. It's intermittent. Increasing in frequency, but still intermittent. And an issue with the fuel filter or lines does not explain to me why when it's misbehaving turning the key to off doesn't shut the machine down. Of course I could just not understand enough of my machine. :)
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2025 48in. Farm Jack (A66734)
2025 48in. Farm...
2001 INTERNATIONAL 4900 (A67714)
2001 INTERNATIONAL...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
