850 Trans Fluid Change
/ 850 Trans Fluid Change #1
greenmachine
Since this isnt my machine and I have no manuals, I see that it has 2 drain plugs (one in the front, one at the rear).. So i drained it from both, pull the strainer, decided to replace it along w/ the hydraulic filter.. My question is do i need to fill in 2 places on the trans now or does the main fill hole fill everything? Thanks
Joe
/ 850 Trans Fluid Change #2
Just fill with THF (Tractor Hydraulic Fluid) through the hole with the dipstick next to the gearshift on top of the trans. Fill to proper mark on dipstick. Run the hydraulics (if any) through their full range of motion and recheck. The trans sump is also the reservoir for the hydraulic system. The reason for two drains is that the design of the trans allows oil to collect in two sumps and the oil won't all drain through one drain.
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
