850 project
/ 850 project #1
R Barger
Gate City, Va
YANMAR YM336D/W Loader JOHN DEERE 850/ W Loader 2WD&4WD Kubota RTV X900 Mahindra 4540 4WD w/Loader
I picked up a 850 4wd with a model 80 loader Friday and there are a couple of brackets I can't identify.
/ 850 project #2
Belly mount mower?
/ 850 project #3
Model 80 loader mounted and works fine without using these brackets? or is there a mystery on how to mount the loader?
/ 850 project #5
They don't look heavy enough to have anything to do with the loader. Were they mounted to the tractor when you got it?
/ 850 project
They were just as you see not attached. the loader was attached and all brackets correct going by the manual for the loader. The way they are made the belly mower sounds correct. They look to bolt onto the loader rear bracket Thanks for all the responses.
/ 850 project #7
Nice find. Those 80 loaders seem hard to come by. I eventually found a 950 with a 75 loader and was thrilled to get that.
/ 850 project #8
Those brackets bolt just to the inside of the loader mast uprights, they are the rearmost mounting bracket for the 8A backhoe mounting frame
/ 850 project
The tractor has a spun bearing but very repairable. It has power steering and a Curtis cab. This is my third 850. I now have 2 4wd's and one 2wd. I am going to do the repair soon.
/ 850 project
The previous owner had owned the tractor since it had 150hrs. He didn't say anything about a backhoe. I have a LW6 3pt backhoe that I use on my Yanmar YM336D. The brackets might be of benefit if I use the hoe on th 850.
New/Unused Electric Winch (A65583)
New/Unused...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
CATERPILLAR D4H CRAWLER DOZER (A64277)
CATERPILLAR D4H...
90in. Work Bench (A65640)
90in. Work Bench...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
