790- The REAL Test....
/ 790- The REAL Test.... #1
790guy
This is the first time I really got to use the 419 loader on my 790. with only 8 hours I felt It was time to give it to her! I ordered 22 yards of 1/2 traffic bond gravel to fix up my 700 foot driveway. Moved the majority only in a hour and a half.
Loader would not move if you took too much off the bottom. but with practice I WAS able to fully load and lift the bucket. a full bucket is much more than what they say it can handle. I am pleased with the results. I feel no need to play with pressure settings. this material is about as heavy as you will find.
Rating B+
for what the tractor is, I'm Impressed!
/ 790- The REAL Test.... #2
790guy
Glad the loader is working nicely for you.
Yep... with a full load it doesn't like to come up very high. It doesn't bother me at all. I like heavy loads near the ground anyway.
A pile of stone is good practice/experience. When you go at a pile of fill dirt/clay or something packed in hard, you may have to try a couple other techniques to get the material loose and loaded.
/ 790- The REAL Test.... #3
Strongly suggest you up your front tire pressure to around 23 PSI or so...
It does help...
/ 790- The REAL Test.... #5
The only problem I have had was trying to lift full buckets of gravel dust and dump them into the dog kennels. The fence is about 5' high and I would have to empty about 25% of my load to get it high enough. With regular driveway gravel - I haven't had a problem.....
2011 Kenworth T800 Truck T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2011 Kenworth T800...
2009 FREIGHTLINER M2 Slick Line (A67714)
2009 FREIGHTLINER...
Polaris Ranger 4x4 Gas Utility Cart (A66734)
Polaris Ranger 4x4...
Tow arm attachment (A64194)
Tow arm attachment...
x (A68191)
x (A68191)
2019 KENWORTH T880 (A67714)
2019 KENWORTH T880...
