790 front axle broken
/ 790 front axle broken #1
godaddy
Hello to everyone! I'm new to the forum and came across this looking for info on a ring and pinion for my 01 jd 790. JD wants $770 for just the gears:shocked::shocked: I've been calling around looking for an aftermarket set, no luck so far. I've read previous post on this site about the frontend on these tractors. I've had mine since new in 01. Rebuilt both outter gears, now the pumpkin is gone. If anyone knows of a place I can get a gear set other that jd please let me know. Thanks
/ 790 front axle broken #2
Your best best is a tractor salvage yard. If you do some research, I think you'll find that 790 front axle (at least some components) was shared by the 770 and 670 (there were castings on my 790 embossed with the 670 numbers). It's going to take some grunt work on JD Parts.
Good luck!
Any idea on what caused the gears to go?
Probably alittle to ruff on it. I'm just going to order the set today from jd. It's planting time and I need it now. Beside this issue I've had with it, it's been a good tractor. Done pretty much everything I've needed it to do. Live and learn as they say.
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A59911)
2005...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2018 FREIGHTLINER...
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
