782D compared to gas Cub GTs.
/ 782D compared to gas Cub GTs. #1
EuropaChris
N. Central Illinois
Cub Cadet 2544
I'm a self admitted diesel nut. My motto is "real engines don't have spark plugs". I've been trying to find an excuse to by a diesel tractor most of my life (I'm 37 now), but up to this point, haven't had a good enough one. So, I've been happy with my '05 2544.
I did run across a used diesel Cub GT (782D or similar model) last year, but never stopped to see it because I'm sure my checkbook would have had my pants severely on fire.....
But, I wonder what the Kubota diesel Cubs are like to use? I assume that the Kubota engine winds up to 3600 rpm, same as the gas engines? It would make sense as you have to keep the input speeds to the hydro unit and mower deck the same. I seem to recall seeing brochure or spec. sheets mentioning that high engine speed.
Seems to me it would be one LOUD LOUD tractor to use with that screamin' little engine. I know my Jetta TDI really gets loud at that rpm.
I also ran across a YouTube video of a guy with a Kubota brand GT, but it uses a 2-cylinder version of the engine, and I forgot how much I dislike a 2-cylinder diesel (except a JD johnny popper). I mowed behind a Ford 1500 diesel MANY years ago, and always hated that missing cylinder exhaust beat.
Anyway, just looking to start some discussion on diesels.
Chris
/ 782D compared to gas Cub GTs. #2
Chris,
I have no Cub diesel experience but I have owned a Ford 1220 compact for about 5 years. I've been completely happy with that purchase, I use the loader more than any other attachment. I believe the rpm's are set to 2500 to get the PTO's operating at the 540 speed.
It's just amazing how fuel efficient the diesels are. I tried to get a belly mower for the Ford but the PTO was removed prior to my purchasing it and it couldn't be located.
I mow with a Cub 5252 or 1872 both really nice Cubs. However the 5252 uses about half the fuel with the Kohler Command as the 1872 with the Magnum.
I've looked at a number of diesel cubs on Ebay and at auctions, I just haven't found a good enough deal yet.
Why does diesel fuel cost more than gas, isn't it less refining to make diesel?
Here's a couple of Ford pics.
Curt
/ 782D compared to gas Cub GTs. #3
Curt
Diesel fuel is produced before gasoline during the cracking process and is less refined so should be cheaper to produce. OTOH diesel fuel contains more BTU's per gallon than gas does. The price, however, seems to be based more on supply and demand. In the winter when heating oil (which is a level below diesel fuel) is in high demand, there is less crude available to make diesel. In my area (NE Ohio) diesel has been a little cheaper than gas for the past year or so. When gas was $3 per gallon, diesel was around $2.79.
Bob B.
/ 782D compared to gas Cub GTs. #4
Bob B.
It's the old supply and demand philosophy!
Thanks Bob.
Curt
/ 782D compared to gas Cub GTs. #5
The 782D was the first diesel garden tractor to hit the market, right after MTD took over Cub Cadet from IH. They plopped a Kubota diesel into the stock 782 tractor, and it worked excellent. Many are still in service today.
I have messed around with quite a few 782D's. They are not loud, they actually have kind of a nifty sound to them, not unlike any other Kubota/Yanmar 3 banger out there today. The engines can last several thousand hours, most easily outlive the rest of the tractor they are in. The 782D uses a large muffler mounted outside the hood to keep it quiet- the muffler can be bolted on horizontally or vertically.
The old 782D has one small problem. It uses a standard size garden tractor battery, mounted under the seat just as it was in the gas 782. These batteries don't have enough grunt to crank the diesel over when it is cold out, and you can't fit a bigger battery in there. Only a problem if you desire to use the tractor in the winter. Otherwise, if you see a 782D in good shape at a nice price, (They still fetch good $), jump on it.
-Fordlords-
-Fordlords-
Thanks for the info! I just assumed due to the high speed of the engine that they would be pretty raucous, especially if the cooling fan ran at that high speed also. Evidently not!
I did read here on the group about the cooling system issues of these tractors ingesting all sorts of dust, fuzz, grass debris, etc. and clogging up the radiator frequently. But I suppose that can be managed.....
But indeed, I thought the same about putting a multi-thousand hour capable engine in a tractor that might only make a thousand or so hours, two thousand tops. I mow an acre with my 2544, and only have 75 hours on it in a little over two years mowing. It would take me a LONG time to wear out a diesel.....
I'll have to keep my eyes open for one of these gems in clean shape locally.
Thanks!
Chris
/ 782D compared to gas Cub GTs. #7
diesel USED to be cheaper, but nowadays with the ultra low sulfur mandates, the refining is pushing the cost higher than regular unleaded. Bummer.
anthony
/ 782D compared to gas Cub GTs. #8
Bob B.
Dieselfuel , home heating oil and fuel oil are all the same thing here.
/ 782D compared to gas Cub GTs. #9
Even if gasoline is a little cheaper than diesel, the Kubota diesel (even an old one) will still use quite a bit less fuel per hour than a comparable HP gas engine, making it worth it. The diesels definitely pay for themselves over the life of the tractor, if you can swallow the initial cost to buy one.
Diesel advantages: Considerably longer life, liquid cooling, less fuel use, more torque
Diesel disadvatages: Harder cold starting, more initial cost, possible fuel gelling, expensive repairs (though not often a factor on Yanmar/Kubota diesels)
-Fordlords-
-Fordlords-
We just had an extended power outage due to some pretty nasty rains, lightning, etc. I FINALLY had the chance to use my backup generator "in combat". It's a ChangFa (Chinese) R185 hopper cooled diesel (about 8hp) coupled to a 3.5kW generator head via 6-rib industrial L belt & pulleys.
I put about 8 hours on it, average load about a kilowatt (fridge, freezer, lights) and it used maybe a gallon of diesel. It also used several gallons of water in the hopper......could be an issue during an extended outage as the generator won't start my current-hog of a well pump....
chris
/ 782D compared to gas Cub GTs. #11
That doesn't sound good. Automotive diesel fuel is usually #1 in the summer and changed to #2 in the winter to prevent it turning to parafin from the cold. Burning diesel fuel in a home furnace would be a waste of money since heating oil is generally cheaper.
Bob B.
/ 782D compared to gas Cub GTs. #12
Bob B.
There is no difference between diesel fuel and heating oil here.
Like I said before It's all the same stuff around here.
/ 782D compared to gas Cub GTs. #13
I hope the price is different at least - like no Road Tax on the heating fuel. Could be an opportunity for someone with a diesel vehicle to cheat Uncle Sam. How do you know that it's exactly the same?
Bob B.
/ 782D compared to gas Cub GTs. #14
1*I hope the price is different at least - like no Road Tax on the heating fuel. 2*Could be an opportunity for someone with a diesel vehicle to cheat Uncle Sam.
3*How do you know that it's exactly the same?
Bob B.
1*They take diesel fuel and dye it red-There is no tax on the red stuff.
This can be used in vehicles or for heating homes.
2*Nope that's why it's red.
3*I can buy it from the bulk plant here that sells the diesel dyed or without the dye or from 2 distributors who says it all the same stuff also.
One of the distributors buys from the bulk plant.
They only have one fuel: The only choice you have is red or not red.
/ 782D compared to gas Cub GTs. #15
Home heating oil is #2 winterized diesel fuel, dyed red to indicate it is untaxed diesel fuel. Taxed pump diesel, either #1 or 2, is not dyed. The Kubota diesels used in the Cub models that had them will run on either (farms typically receive untaxed dyed fuel in their tanks for agricultural use), but diesel engines tend to run better on pump diesel, especially that sold at more frequented pumps. This is because diesel fuel becomes stale quickly, and works better in engines when it is fresh and properly filtered.
-Fordlords-
/ 782D compared to gas Cub GTs. #16
-Fordlords-
The bulk plant here supplies the exact same fuel to the pumps that I can get directly from them, so how can it be any fresher from the pump when I got it before the pump did?
