770 tractor years made
/ 770 tractor years made #1
kartvines
Can any body tell me how to determine the age of my 770?
Can you tell by knowing the vin code?
My vin # is M00770A161090*.
/ 770 tractor years made #2
Here's some general info
This site lists by Serial # but stops at 1996
By their serial # convention, I'd say yours is a 1997.
/ 770 tractor years made #4
I know of no other place unless you have some paperwork, receipts or otherwise that list the year.
Does the person you purchased it from know what year it is?
/ 770 tractor years made #5
Years Made: 1989-1998
Horsepower - PTO: 20
Horsepower - Engine: 24
Horsepower - Drawbar:
Horsepower - Range: 20
Engine - Make: YANMAR
Engine - Fuel: DIESEL
Engine - Cyl(s) - CID: 3/83.1
Transmission - Standard: SG
Optional:
Forward / Reverse Standard: 8/2
Forward / Reverse Optional:
MFWD - Standard / Optional: OPT
Tires Standard - Front: 4.00-15
Tires Standard - Rear: 9.5-24
Wheelbase - Inches: 61
PTO Type: LIVE
3pt Hitch Cat I: True
3pt Hitch Cat II: False
3pt Hitch Cat III: False
Hitch Lift: 815
Hydraulics - Type: OPEN
Hydraulics - Cap: 4 GAL
Hydraulics - Flow: 5.6 GPM
Hydraulics - Standard Outlets: OPT
Cooling Capacity: 1.27 GAL
Fuel Tank Capacity: 6.3 GAL
Cab Standard:
Weight: 1930
New Price: $12,739.00
Serial Numbers On File
Serial: 100001 | Year: 1991 | Plate Location: REAR OF TRANS CASE BELOW PTO
Serial: 1001 | Year: 1989 | Plate Location: REAR OF TRANS CASE BELOW PTO
Serial: 115001 | Year: 1992 | Plate Location: REAR OF TRANS CASE BELOW PTO
Serial: 120001 | Year: 1993 | Plate Location: REAR OF TRANS CASE BELOW PTO
Serial: 130001 | Year: 1994 | Plate Location: REAR OF TRANS CASE BELOW PTO
Serial: 140001 | Year: 1995 | Plate Location: REAR OF TRANS CASE BELOW PTO
Serial: 150001 | Year: 1996 | Plate Location: REAR OF TRANS CASE BELOW PTO
The info is from tractortips.com. Looks like that 770 must have been manufactured in '97 or '98.
Tough machine, the 770! I owned it's smaller brother, the 670 and now own the successor, a 790.
I really like 'em!
/ 770 tractor years made #7
Thanks Tractordata.
Yours was the first page/place I went but the serial #'s weren't there at the time. Thanks for updating.
BTW, welcome to TBN!!
Brian
/ 770 tractor years made #8
Tractor was sold out of dealer in Montclair, CA on July 29, 1997
Serial Number Component Invoice / Transfer Date
CH3045D016735 ENGINE, D. 30Apr1997
Build Codes Code Description Invoice / Transfer Date
1001 POWER STEER CONT LIVE PTO 30Apr1997
2401 25X8.50-14FRT&13.6-16R(4)YAN 30Apr1997
7000 LESS SCV 30Apr1997
8000 LESS MID PTO 30Apr1997
Thank you very much , that is more information than I thought I would ever have.
/ 770 tractor years made #10
Thanks. The site is just a hobby, so I don't usually get around to updating anything unless someone asks for specific information.
I went to the dealer where the tractor was sold, and you had more information than they did, saying that all of the older data is nolonger on the computer, since they were bought by Arizona Tractor.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
BODY LOAD TANK (A67714)
BODY LOAD TANK...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A67714)
TWO PALLETS OF HYD...
2017 Ford Transit 250 Cargo Van (A66736)
2017 Ford Transit...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2017 Ford F-150...
