770 questions
/ 770 questions #1
daTeacha
Veteran Member
Funk, Ohio
Could you guys fill me in on the 770? As far as I can determine, it's the immediate predecessor of the 790, running a few less hp, but otherwise the same tractor.
I've found one with under 600 hours and turf tires. Nothing else on it, just the bare tractor. It's currently owned by a farmer/equipment dealer who has had it for over a year due to it's size and lack of hydro. Mostly he sells used big stuff but picked this up at an auction and none of his usual clientele are interested in it. He said he'd 6500 for it and would probably be able to locate either ags or R4 tires and rims if I wasn't in a big hurry.
I'm wondering what the loader might be like in terms of price and capability, plus is the JD loader a more or less permanent installation or is it a quick on-off? What non-JD loaders might be made for it?
/ 770 questions #2
The 770 was built from 1989 - 1998. In 1999 it was replaced by the 790. It's 83 cu. in. direct injection engine is rated 24 HP with 20 HP at the PTO. With 4 wheel drive, it weighs 2,150 lbs. With a 70 loader, and 4' bush hog, weighted tires, a full tank (6.3 us gallons) of fuel and a 200 pound operator, it would weigh in the neighborhood of 3,500 - 3,750 lbs.
My 770 was built in 1998. It was originally leased to one of the California vineyards without a Front End Loader (FEL). It was used to haul "Gondolas" in the vineyards during harvest time and was returned off lease in a year or so with 53 hrs.
It is common for all big three dealers around here to each lease 50 or more new tractors to local growers, usually for a year or less. When they get them back off lease, they install a new FEL. This one has a JD series 70 loader with a 54" (7 cu ft) bucket. Lift capacity at full height (77") is 755 lbs, at 18" it is 1190 lbs. It is a quick release type. JD has subsequently replaced this loader.
The first purchaser had it for about 4 years, and sold it to me with 223 hrs. The purchase for this 4 wheel drive tractor included the loader, a 54" box blade, and a really old set of discs. The rear tires (R4) were loaded and the front tires were reversed to widen the track a few inches. He used it mostly to bush hog and ran a 5' cutter which he had previously sold separately. He claimed to have removed the FEL and said it was a 5 minute job, to remore and reinstall, it is but best done on a solid surface. With a loader, you will absolutely want loaded rear tires and either a substantial rear implement or a ballast box to keep the tractor on the ground.
I purchased this tractor in May 2003. I have subsequently added a 4' JD LX-4 rotary cutter and a 7' landscape rake.
This was my first tractor as I am a guy from the suburbs so I knew little about it. I had been looking for a clean tractor this size for over a year. He was aksing $11,500 and he settled for $11,250 including the implements. He receiver 23 calls on this tractor. It was exceptionally clean and had been garage kept since he bought it, and it was clearly the cleanest tractor I had seen and had the lowest hours on any tractor. I have no reason to believe the hours were not accurate.
I've used it for bush hogging, moving materials with the loader and spreading it with the bucket and the landscape rake. I've also used the box blade for grading. I now have 406 hours total on the tractor.
My opinion of this tractor from 32 months of use is that it is an excellent, reliable tractor. I have done all the service myself; oil and filter changes, lubrication, changed the hydraulic fluid and the air and fuel filter and adjusted the clutch. Service is straight forward and relatively simple, with no special tools rquired. Everything is easy to reach. The only "breakdown" I've experienced was a flat right front tire, twice, from running over nails. I replaced the tube on the second go around because it already had two patches.
Fuel consumption at rated rpm is a little over a half gallon per hour. Oil consumption is non-existent. It does not drop on the dipstick between changes. I live in a warm climate, so I can't speak to cold starts. It always fires on the first crank, and idles smoothly. The 4 wheel drive provides needed traction when slippery and when using the loader. The power steering is very nice to have. It goes 11 mph in top gear which is plenty for the short trips on the road around my 6acre corner lot. With a dual range 4 speed gearbox, I can always find one of the 8 gears to be right for my needs. Some swear by hydrostatic transmissions as the only way to go, but I have not found the manual gears a problem. I did not get the Mid-mount PTO option on this tractor and have not missed it. I use a 48" garden tractor to cut my 3/4 acres of lawn so I did not need a finish mower.
I would buy this tractor again in a heart beat, and it is probably worth close to what I paid for it right now.
A contractor friend of mine that built my current home also has a 770, around a 93 - 95 model. It has a loader and a back hoe. His has had a lot harder life than mine and has over 1,000 hrs and has been trouble free for him as well.
As far as the one you're considering, other than 4 wheel drive and mid mount PTO, I don't know of any other options. I'm not sure if power steering is standard or an option. It's darn nice to have. One of the reason these are reliable tractors is that they are basic, and don't have a lot to break. The 3 cylinder Yanmar engine is pretty much bullet proof and has been in use for many years.
Their hydraulic capability is probably average for this size tractor. I know there are other brands this size that lift a little more, but when I get that bucket full of sand or gravel and get it up high, I don't want anymore capacity. It is capable of loading a 2-3 yard dump truck on an F-450 chassis and not much higher without climbing a pile of dirt to get it up higher.
As to the cost of the loader, I would suspect a new JD loader would be in the range of $2,500 - $3,000. Call a JD dealer for a price on a new loader to be sure. Look around for a used loader. If you plan to do much with the loader, 4 wheel drive is pretty nice. It also helps keep the tractor from sliding on the side of hills when turning as it will just pull the tractor around and up the hill.
I don't know the condition of that particular tractor, but under 600 hrs on that engine, assuming it was maintained, is really nothing.
These are solid, reliable basic compact utility tractors that have been around for years in one form or another because of their reliability and capability.
I am sorry for this very long post, but I hope that it answered some of your questions.
/ 770 questions
Thanks for the information. I don't know about the power steering on this machine. I have to presume it has the mid PTO since it has turf tires, but I really don't care about having it or not unless it's something that might get hung up on a rock or stump in the woods. The tractor was in the back of a large shed, tucked in behind a combine with tires that probably weigh more than the 770 and a huge spray rig. It was cool (35 F or so) and hadn't been started in about 2 months but kicked right off when the guy turned the key.
/ 770 questions
Right now, I'm thinking the combination of adding the loader, valves, and possibly power steering is probably going to put it pretty high in the price bracket compared to something already up and running.
I need to see if it has PS, or maybe you guys can tell me if it really needs that feature. My B7100 with loader doesn't have it, and I don't have any problem steering that with a loaded bucket. That's only about 500 lb, and the whole rig, including the load in the bucket, is lighter than the 770 without the loader. It also has narrow 12" ag tires in front as opposed to the turfs currently on the 770.
/ 770 questions #6
If the tractor is a four wheel drive machine, it will have power steering. With the 2WD 770's, power steering was an option.
That 770 is a nice tractor...I hope you buy it.
/ 770 questions #7
The serial number located below the rear pto will tell you what year it is:
1989 1011
1990 4111
1991 100001
1992 115001
1993 120001
1994 130001
1995 140001
1996 150001
1997 160001
1998 170001
Hope this is of some value to you.
Roy had a 670 and now has a 790, so he is familiar with these tracors and knows a lot more than I do about them.
/ 770 questions #8
Sometimes an overlooked advantage of power steering, is that when the front tire hits the rut or rock, the steering wheel doesn't transmit that load to your hands. I researched the 770 and 870, and for the marginal difference chose the 870.
/ 770 questions #9
You're ight on that, except that the teacher has only found the 770.
The 870 is 600 lbs heavier, 3-4 hp more powerful, has 9 forward gears instead of 8, and an 1800 lb 3 pt lift instead of 880.
The 870 may fit his needs better as well.
Either way, both great Green tractors.
John Deere 18ft. 3 Point Field Cultivator (A65640)
John Deere 18ft. 3...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
(7) Trailer Tires (A65640)
(7) Trailer Tires...
2001 Volvo Sleeper (A62613)
2001 Volvo Sleeper...
2003 GMC C4500 Crew Cab Dump (A62613)
2003 GMC C4500...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
