758C BH stabilizers
/ 758C BH stabilizers #1
billfires
Southeastern Mass
New Holland 1920
Does anyone know if it's normal for the stabilizers to only be able to lift the tires less than an inch off the ground? It is mounted on a NH 1920 with turf tires. I know they are not at the limit of their travel because if I lift the back with the BH boom they will extend further. It sounds like a relief valve is opening up when they stop. Any info or suggestions appreciated. Thanks
Bill C
/ 758C BH stabilizers #2
Bill:
Any backhoe I have seen in operation could lift the tractor well off the ground. Some operators even use them to do small side shifts.
Egon
/ 758C BH stabilizers #3
New Holland has set the pressures on these tractors to just stabilize the tractor not lift it off the ground. if you read the operators manual on the hoe you will see NH say optimal digging is achieved with tractor stabilized and not lifted of the ground hope that helps.
Egon and spencer200 here is an update on the stabilizer problem. The rear tires are loaded with CaCl and are 700+ lbs. Also I weigh a little under 300lbs, so there is the weight of the BH 1000 lbs and another 1000. Yesterday I put the stabilizers down while I was off the tractor and they lifted to full extension. Thanks again for your help.
Bill C
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
2025 GIYI GY-P45 Hydraulic Breaker Skid Steer Attachment (A61572)
2025 GIYI GY-P45...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2003 McCormick XTX 185 XtraSpeed Tractor (A63688)
2003 McCormick XTX...
2019 KOMATSU WA320-8 WHEEL LOADER (A64279)
2019 KOMATSU...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
