755 electrical screw up
/ 755 electrical screw up #1
Cocobean
John Deere 755
Greetings all,
Great forum and Ive used it in the past to chase down problems with my tractor.
My 755 has been cranking slowly so I bought a new battery. In the snowstorm in the dark I inadvertently reversed the polarity on the battery. Realized my mistake but now I have problems. It cranks but no dash lights and no fuel transfer pump. All the fuses appear good. The battery lead sparks and something energizes in the engine when I connect the lug, even with the ignition off.
Any ideas on where to start? Any help would be greatly appreciated as I need to get my driveway plowed!
/ 755 electrical screw up #2
Try to locate a schematic diagram of the tractor to see what you burned out. The dealer may have ideas as well.
/ 755 electrical screw up #3
Probably the starter/solenoid being hit with reversed polarity..making noises.. alternator could be toast too.
Dash lights might be simply blown bulbs.
/ 755 electrical screw up #4
I made the same mistake on a Kubota once. Once I realized my error and corrected it, the system was dead. Turns out the main fuse popped, replaced it and all was good.
I would check the fuses before anything else.
/ 755 electrical screw up #5
Maybe good to check them for continuity.
Is this 755 the "older" or the "newer" model ?? From jdparts, looks like the s/n break for the wiring harness change (older to newer) is at 475000.
Two pages from service tech manual regards the electrical operation and tests.. as you can see, a long list. Where to start??
Thanks all, I知 going through the system now. Not sure if it痴 old or new. I値l let you know what I find.
I did see some smoke from the alternator when I powered it up so I probably fried something in there. I ordered a new one and will see what that does.
Thanks for the help.
KUBOTA BT2912A - 15" PIN ON BUCKET (A64280)
KUBOTA BT2912A -...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2005 Anderson 24ft T/A Dovetail Tag Trailer (A61573)
2005 Anderson 24ft...
2017 CATERPILLAR 980M WHEEL LOADER (A64279)
2017 CATERPILLAR...
