755 electrical screw up
/ 755 electrical screw up #1
Cocobean
John Deere 755
Greetings all,
Great forum and Ive used it in the past to chase down problems with my tractor.
My 755 has been cranking slowly so I bought a new battery. In the snowstorm in the dark I inadvertently reversed the polarity on the battery. Realized my mistake but now I have problems. It cranks but no dash lights and no fuel transfer pump. All the fuses appear good. The battery lead sparks and something energizes in the engine when I connect the lug, even with the ignition off.
Any ideas on where to start? Any help would be greatly appreciated as I need to get my driveway plowed!
/ 755 electrical screw up #2
Try to locate a schematic diagram of the tractor to see what you burned out. The dealer may have ideas as well.
/ 755 electrical screw up #3
Probably the starter/solenoid being hit with reversed polarity..making noises.. alternator could be toast too.
Dash lights might be simply blown bulbs.
/ 755 electrical screw up #4
I made the same mistake on a Kubota once. Once I realized my error and corrected it, the system was dead. Turns out the main fuse popped, replaced it and all was good.
I would check the fuses before anything else.
/ 755 electrical screw up #5
Maybe good to check them for continuity.
Is this 755 the "older" or the "newer" model ?? From jdparts, looks like the s/n break for the wiring harness change (older to newer) is at 475000.
Two pages from service tech manual regards the electrical operation and tests.. as you can see, a long list. Where to start??
Thanks all, I知 going through the system now. Not sure if it痴 old or new. I値l let you know what I find.
I did see some smoke from the alternator when I powered it up so I probably fried something in there. I ordered a new one and will see what that does.
Thanks for the help.
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
1100 GAL PLASTIC STORAGE CONTAINER (A63745)
1100 GAL PLASTIC...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
Sterling 9500 (A63118)
BOB TAIL KILL TANK (A63569)
BOB TAIL KILL TANK...
F-250 SuperDuty (A63118)
F-250 SuperDuty...
