7520 questions
/ 7520 questions #1
jrchafin
Mahinda 7520
Hi all,
I've got my deal hammered out. I'm getting a 7520 with Ag tires, loaded at no charge, 4WD with loader, 511 backhoe, 6' HD brush hog, and pallet forks for right around $40,500 total. Sound like a good price this time? I'm meeting with the dealer next week to finalize.
I'm going to have a 3rd rear remote added. About how much should that cost me? Anything else I should add at this point?
I need to get a trailer to haul this thing. It looks to me like it'll weigh around 11k pounds. That right? (Tractor=7+k, loaded tires 1k, loader 1k, backhoe 1500) How long of a deck will I need to accomodate the loader/bucket and the hoe? Anybody haul anything like this with a smaller trailer? I don't want to spend for more than I need, and I'm thinking a 10k gross weight tandem axle can probably do it fine.
Thanks! Can't wait!
Jon
/ 7520 questions #2
jrlogan said:
Hi all,
Thanks! Can't wait!
The loader weighs around 2,000 lbs. My 6520 4WD, ML275 loader and 511 backhoe weighs in at 11,080 pounds. That is not with loaded tires. That is on the salvage yard's scale. The backhoe buckets add weight also. I think mine hits around 1600 pounds.
hugs, Brandi
/ 7520 questions #3
hugs, Brandi
jrlogan, I concur with Brandi altho I dont have the scale, her figures make perfect sense. Iv always considered mine at about 14K# fully equiped and with 4 water loaded AGs. A rear load with water will be above 1000# at 70% fill. If you use the 11#/G filler liquids itll be more like 1600# for the rears.
The price youre quoted seems good to me. My basic TLB with canopy, grill guard, toothbar, and 2BH buckets cost $37k 2 yrs ago. Xtra remote is around $800. A good idea.
larry
/ 7520 questions
Oh, and what size bucket would you guys recommend for the 511? I will be using it for digging footers/foundations, a large pond, burying utilities, and whatever else. I know 2 buckets sizes may be the better option, but an 18 would work pretty well, no?
Yikes, $800 for an extra remote. What operation would I need 3 rear remotes for? I don't want to drop $800 for something I'll never use, but I'll be happy to if there's a good reason...
Jon
/ 7520 questions #5
I believe the third remote operates the ice chest controls. Makes sure you get the one that comes with the joystick. :)
/ 7520 questions #6
Jon
Two remotes for top and tilt cylinders and the third for hydraulic scarifiers on a box blade or a hydraulic angled rear blade. If you were to get the top of the line Land Pride rear blade with all the hydraulic goodies, then you would need 4 for the blade and 2 for top and tilt if you had them also. So if you will be doing much grading, it would be real easy to need 6 rear remotes.:eek: I do not know about ag stuff that you might be pulling, but there has to be a reason that the ag only tractors have 2-8 remotes.
I bought my third remote for $600 shipped to me and it took about an hour to install it. I highly recommend the front weights if you are going to do much mowing with the loader off. Oh, and if you are going to do a lot of mowing, I recommend that you do take the loader off.
If you can swing it, get 2 buckets. You will use both for the things that you listed. I have a 580 Case backhoe and 13", 16", and 24" buckets. There are times when I wish that I had either a 30" or even a 36" bucket. Get the 18" and a bigger one also.;)
Good luck with your new machine and please post some pictures when it arrives.:cool:
/ 7520 questions #7
jrlogan said:
Hi all,
Thanks! Can't wait!
Jon
You need to think a bit more about the trailer. A 10k gross trailer should weigh in at what ~3000 lbs? Whatever, at 3k empty weight, you only have 7k left.
I think 4,000 pounds over is pushing it too much.
My other question would be about the 6 foot brush hog. The 7520 will easily handle much more than that. I bought a ten footer for mine though I have not yet had it out.
Thing is, if you have a lot of acerage to mow, that 6 footer may waste too much of your time. You end up with about a five foot swath due to trying to keep your overlaps right so you don't miss spots.
Great tractor though, I really like mine so far.
/ 7520 questions #8
Jon
Jon,
I have a 12 and 24 inch bucket. I kick myself now for not getting a 36 inch ditching (no teeth) bucket. I used the 12 inch bucket a little, but since I installed the thumb, I will only use the 24 inch bucket until I need to run sewer ditches. The thumb meshes with the teeth on my 24 inch bucket, but not my 12 inch bucket.
Remember when you think about trailer weights, add the weight of the trailer to the tractor. My 20 foot gooseneck trailer weighs 2600 pounds on the axles while hitched to my truck. So the big RED Beast and the trailer weigh in at 13,700 pounds. 300 pounds less than gross of 14,000 pounds.
hugs, Brandi
/ 7520 questions #9
In the "for what it's worth" column, get a 12 and a 24 in buckets for the 511. I use the 12 pretty much for trenching, etc. Its also MUCH better for digging up stumps, etc than a 24. Yeah, filled rears will be about 1400 lbs or so. FEL will approach 1800lbs. Get a 78 or 84 inch REL bucket. A 6 foot bush hog will not cover your rear wheels....a 7ft will...spend the $ and get a good one with twin tail wheels (more even cut). If you look into box blades, also get a 7ft HD unit as your tractor will turn a normal use one into a pretzel if you hit something that doesn't give....Figure that the tractor/FEL/BH/loaded tires will weight 13000 lbs. Give yourself some leeway on the trailer....Just my $.02. BobG in VA
/ 7520 questions #10
bindian said:
Jon,
hugs, Brandi
Hi Brandi. I don't want to get off of the main topic here as the trailer issue has been beaten to death but I think I will add this as the trailer is important to Jon's plans.
Depending on your state and how you are registered, thinking that the vehicle pulling the trailer carrying some of the weight may be trouble.
To cut to the quick here, DOT can ask you to disconnect your trailer and weigh the trailer by itself which could be trouble.
Back to the bucket discussion. You want to watch the bucket width if the ground that you are digging has a lot of stones in it, especially hardpan. Too narrow and the stones don't have enough room to dislodge slowing down your digging.
Two buckets are better, three perhaps best. Easy for us to help spend Jon's money.
/ 7520 questions
Thanks for the input guys.
I'll admit, I was actually thinking of getting a 14k gross weight trailer, but I wanted to see what you guys would say if I said 10k!:rolleyes: 'Nuff said.
As for the backhoe bucket, there aren't a lot of rocks in my area. For building a pond, I will be moving LOTS of dirt. Can this thing really handle a 36" bucket? I know when the bucket gets too wide, your digging becomes less effective and you end up wasting time. But if it can handle it, maybe I should just get an 18 and a 36?
Jon
/ 7520 questions #12
Who in the world is telling you that?:confused: That's totally not true. A loaded trailer NOT hooked to anything is simply a strange storage device. There are plenty of things they CAN do, but a combination vehicle is a combination vehicle. There are some things they CAN do along those lines, but it requires for parts of the combination to be put out of service for other mechanical reasons.
Back OT though... get a bigger trailer... the loader weighs in at 2k like Brandi said...
/ 7520 questions #13
jrlogan said:
Hi all,
Thanks! Can't wait!
Jon
Jon,
Here is a photo of my 6520 on my trailer. It is a 20 foot trailer and as you can see, the gooseneck comes in handy for the loader to perch. If you haul with loaded tires, depending on the weight of the trailer, I would say you need a 18,000-20,000 pound rated trailer. What kind of truck do you have to pull this?
hugs, Brandi
/ 7520 questions #14
Jon
Jon,
Once I hit 100 hours on the hour meter, I cranked the RPMs to the firewall and my 24 inch bucket heaping full with clay and wet mud (water drips out) digs and lifts and swings just fine. That is with my punny 11 gpm pump. Yours has a 17 gpm pump. It will handle 36 inch wide buckets. Bare in mind the wider you go, the more the load will weigh and the BH acts according. Mine takes a time to lift a heaping full bucket at full boom and dipper stick reach.
hugs, Brandi
/ 7520 questions #15
QRTRHRS,
Yes, you are off in left field. I was only referring to overgrossing a trailer. The weight on the gooseneck hitch is not considered trailer weight when figuring if your trailer is overgross according to the data plate. It would all be moot for me anyway, as my 3/4 ton diesel has an automatic transmission and is only rated to pull 9800 pounds, while the same truck with a stick can pull more. But down here in the Grand Republic of Texas, if Smokey the Bear sees you are pulling a trailer with farm tags and loaded with horses or cattle or hay or tractors............they leave you alone unless you driving reckless.
hugs, Brandi
/ 7520 questions #16
Jon,
If you are doing a lot of clearing of brush and trees, get the 78 inch loader bucket with the skid steer quick attach option. I ordered mine with the 78 inch bucket. It came with an 84 inch bucket. I love that bucket until I get in tight in the trees. I have hung the bucket sides many of times on trees as I was turning and trying to back out. My Big RED Beast lifts that 84 inch bucket heaping full of clay and gets on going.
hugs, Brandi
/ 7520 questions #17
Brandi,
You said your trailer is a 20', right? Is that the bed length or from the back edge of the bed to the gooseneck hitch? I just imagined that a 20' would be a little longer, but maybe I'm just underestimating the length of your tractor.
/ 7520 questions #18
xlr82v2 said:
Brandi,
Brian,
The trailer bed is 20 feet long. My barn is 30 feet deep and stopping with the backhoe bucket at the back door, my loader bucket is about 4 feet from the front door. The Big RED Beast is huge. When folks stop by the house and see the RED digging machine, they say..........That's a big tractor!
hugs, Brandi
/ 7520 questions
IT OFFICIAL. I TOOK THE PLUNGE!!
I called around, found the best price I could, then called back the local dealer and asked if he wanted to deal. He didn't even ask what price I had gotten, but told me that I'd be buying my tractor from him, and that he'd call me tomorrow. Apparently he has connections with the regional Mahindra rep, and got me the following:
7520 4WD with loader, 511 backhoe, 6' HD brush hog, and HD pallet forks for a grand total of $38750! Even better, I currently live in WV and this dealer's in VA, so I don't have to pay sales tax. He said he'll have it in a week.
The reason for the 6' brush hog is I will be cutting some trails through the woods, and I need something narrower than the tractor. In the fields I will be using a disc mower and other hay cutting equipment.
I will be towing with my Dodge Ram 2500 (3/4 ton) with Cummins diesel. It's rated to tow 15k pounds.
I'll post some pics when I get it!
/ 7520 questions #20
Jon,
Congradulations! What size BH buckets are you going to get? What year is your Dodge/Cummins?
hugs, Brandi
