7520 lift capacity
/ 7520 lift capacity #1
jrchafin
Mahinda 7520
Hey all,
I have a 75204wd with loader, one heck of a lifting machine. Rated to lift 3900 pounds to full height from the pivot pins.
I have an outdoor wood boiler that is going to be delivered soon on a pallet. It weighs around 4200 pounds. Do you think I'll be able to lift it? I just need to get it off the trailer (about 3' high), and then set it on it's new home, so obviously I won't be lifting it to full height. But of course, the weight will be centered farther out than the pivot pins.
Thoughts? Opinions?
Jon
/ 7520 lift capacity #2
That's a tough one.
On one hand, you have a little more lifting ability at lower heights than at full height, but on the other hand, at your bucket center, figure on only being able to lift 70% of your capacity (to full height). In front of the bucket, such as with forks, you may lose a little more yet. You might actually be close if you're only going 3 feet.
Only one way to find out, right?
/ 7520 lift capacity #3
I think it will lift it if your not lifting high. Put a good amount of counterbalance weight on the rear and keep it low as you can when traveling with it. You may also want to add some air pressure to the front tires. Fill to the maximum pressure stated on the tire. Good luck and be careful.
/ 7520 lift capacity #4
If your bucket is QA, drop it off before you do your lift. That may help some.
/ 7520 lift capacity #5
Hey all,
Thoughts? Opinions?
Jon
As strong as that machine of yours may be, i wouldn't try it. it's not about your lift capacity, it's about geometry, awkwardness and the danger of dropping or damaging it. right tool for the right job and all that. i'd enlist the help of a small crane or a large fork-lift.
Theo
/ 7520 lift capacity #6
My guess is that you will pull up to it and never be able to lift if off the trailer. Will you be using forks to attempt this. Gut feeling is that you won't get it off of there with it. Like others have said, ballast and drop it to the ground nice and smooth, but do it pretty quick..
I hate to say it, but I agree with Rback, I don't think it'll do it. But there is only one way to find out, and I will let you guys know.
I will have my backhoe on for counterbalance. No problem there. Yes, I will be using forks. The problem is the center of gravity will be so far forward from the pivot pins, that I think I'm dreaming to even attempt it. It's not like the boiler is 1 foot wide and the weight will be just a foot or so forward. It's 5 feet wide. And that is why...I have a backup plan.
Theo, I would gladly rent a forklift and do it right, but I live out in the sticks and the nearest rental place is over an hour away.
/ 7520 lift capacity #8
I jumped in here because I was asked to do something very similar a couple years back. lift capability (lbs) wasn't the issue. lift geometry was. the guy ended up getting a mobile crane guy in there for short money and everything worked out perfect.
Theo
/ 7520 lift capacity #9
Hey all,
Thoughts? Opinions?
Jon
I am fairly sure it won't lift it. Adding 2.5' of distance to the center of the weight makes a huge difference. The only hope would be to drop the bucket and rig up chains at or near the pivot point, but then you take a chance of having the boiler on the hood. If you do this, lift it a couple of inches and have the truck drive out from under it. Then lower within a foot of the ground before you move the tractor even a little.
Of course the load might not be liftable in that manner. It may require being lifted by the pallet. Another option is to have it unloaded in town by a forklift and put on a real low trailer that you can rent/borrow. Tow it home and lift/drag it off the trailer with your tractor. Being 1 foot off the ground with a big load is more easily managed then being 50" off the ground.
Where there's a will, there's a way, but be careful!
It takes a really big tractor to do the work of a small forklift.
/ 7520 lift capacity #10
I doubt it too, but I didn't understand the bit about it being delivered on a trailer that is 3ft high.
This isn't coming out the back of a semi-trailer, so there isn't that "going off the edge" moment.
Is it coming on an equipment trailer that you can drive onto ?
If so you MIGHT be able to tip it back toward you (break out force being greater than lift capacity) and "lift" enough of it's weight to drag it off the trailer.
You MIGHT be able to cheat your loader, but that is probably dangerous.
I would be VERY leery of taking it more than a few inches off the ground and bumpy ground would be enough for me to SERIOUSLY consider a small crane.
In all honesty - yeah, I would probably try it
and I would probably cheat the loader too (-:
Edit:
I just went to the Mahindra web site, just guessing you have the ML275 loader.
ML275 specs say 3900 lbs lifting, 5500 lbs break-out.
I would almost certainly try it, maybe by cheating the loader, which is not a suggestion that you do.
:End Edit
/ 7520 lift capacity #11
Well, I'm going to go against most everybody else here and say that I think that it will do it. I am fairly sure that I have lifted that much weight before, but and this is a huge BUT, I was lifting junk and or not anything of any real value. When in doubt, it is better to be safe and use a crane or fork lift, especially when dealing with anything of value. ;)
/ 7520 lift capacity #12
The trailer that your boiler is being delivered with, what happens if you cannot make the lift? If this was a situation where the boiler was on your own trailer, time or possible damage to the trailer would be less of an issue.
Other than that, I too would give it a shot. I would see if it would pick the weight and if it did, I would then lower it. If that worked then I would pick it and have the trailer pull away prior to lowering it down close to the ground.
By the way, are your forks rated enough for the weight?
/ 7520 lift capacity #13
What size is the pallet? Can you somehow duplicate the weight with 525 gallons of water on a pallet? If so, you would know before hand what to expect.
/ 7520 lift capacity #14
I didn't know you were going to use forks, and with that in mind I doubt you will lift it that far out. Most ot those boilers have a lift loop that is located in a well balanced position, and if it will not hit the grille, I would drop the bucket and lift from there. Every bit of geometry advantage you can get, you will need. Good luck and be save.
/ 7520 lift capacity #15
Also extend the boom and dipperstick on your backhoe. Put your largest bucket on the BH and add weight in the BH bucket. Remove your loader bucket too. I think if you try to lift it and can just get it "lite" on the trailer, let the truck driver pull out from under it. Are your tires filled? If you have R1 tires, I am sure they will go flat with this load. I have flattened my 6520 tires lots of times while moving large stumps and whole trees. Same lift cap. as your 7520. But if your rear gets too lite while trying to lift..............get a fork lift and save you some grief.
hugs, Brandi
/ 7520 lift capacity #16
I don't think it will lift it. I unloaded a pallet of metal roofing from a flatbed semi that was 21 ft long , about 4 ft wide, 8 inches high, and weighed about 3045 lbs. I could only lift it about 1-2 inches off the semi flatbed and no more. I used forklift attachment (I think they are rated for 5000 lbs). Once I got it off the truck, I could not raise it or curl the forks back and had to let the load slip off the forks when I lowered the forks. Nothing was damaged but it wasn't the best way to do it. It could have weighed more but you are trying to unload 4200 lbs and that is a huge difference. I put 28 lbs of air in the front tires (Ag) and had the backhoe slightly extended out on my 7520. I think the 70-75% rule works fairly well when trying to figure out whether you can lift something farther out then the pins. My example was fairly close to that.
I would see about having a forklift as a backup at the very least. See if there is someone near you that has one and will help out since the rental place is so far away. The delivery truck normally doesn't want to stick around because you don't have the right equip to unload and you may get charged if you hold him up--probably cheaper to have the forklift.
/ 7520 lift capacity #17
hugs, Brandi
Some very good suggestions here and thruout. Be extremely careful to test the situation gently because you are at a limit. Realize also what Brandi means about getting it "lite". That means either very lite or else very sure of the adequacy of your counterweight, as evidenced by the points touched on in her setup . Elsewise you run a very real danger of tipping forward when the truck pulls out. If you have R1 fronts it would be wise to overpressure them a bit. They are safe to 35psi when seating the bead and even more after the tire is correctly mounted. The R1fronts on the 7520 are larger than on the 6520 too, so support capacity will probably be fine at 35psi. Still, if the hydraulics wont lift and curl you will have to get creatve to set it down gracefully. I would favor increasing the loader relief pressure to around 3000 psi temporarily. This should give you enuf hydraulics to do it.
larry
/ 7520 lift capacity #18
larry
Also, it is **** near impossible to turn with this much weight. While dragging whole pine trees with the root ball end hanging by a chain and needing to turn at a specific spot, say over a gully culvert, I have to lower the bucket to releive all that weight on the front, then reposition when the rears are not getting good solid weight on the thread. Thus 4 wheel drive is essential here.
Also, curl won't be a factor because you will need to chain the load from the loader arm forward cross tube. I think forks will have to forward of a center of gravity issue and the bucket will be removed to save lift capacity. I have removed my 84 inch wide bucket before to lift a large stump this way when it wouldn't lift it using the welded hooks on the top of my bucket. Be careful and good luck!
hugs, Brandi
Sorry about the delayed update guys, I kinda forgot till now. Thanks for everybody's input.
Anyway, as I expected, the tractor would not lift the boiler. Not only that, but because of my work schedule, I had to use my backup plan (which was to have a local business unload it off the semi and then put it on my trailer) right off the bat. So I didn't even try to lift it off the semi, just off my trailer which is 2-3' high. Wouldn't budge it. The boiler does have a lift hook, but I think it's too big to try and lift from above at the pivot pins. Would be crushing the grill, so I didn't try that.
I've got a 14 ton boom truck scheduled to come next week. Think that'll lift it?:D
/ 7520 lift capacity #20
it?:D
Jrlogan,
Then you need a Mahindra bumper and modifly it like I have mine.
hugs, Brandi
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
OK TRUCK & TRAILER SALES PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
OK TRUCK & TRAILER...
PORTA POTTY (A68842)
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 FREIGHTLINER...
2010 International 4300V TYMCO 500x Regenerative Air Sweeper Truck (A66736)
2010 International...
