7520 4wd stuck in neutral!
  • Thread starter Deleted member 41266
  • Start date
/ 7520 4wd stuck in neutral! #1
D
Guest
Today after running a mower conditioner (Ford 538) for two hours with no problem, one of our volunteers (he's an experienced operator) stopped the tractor & turned it off. When he came back to resume cutting, the 7520 would not shift out of neutral. The tractor started started fine, but the shifter could not be put in gear. The tractor is not very old, it has about 320 hours on it.
We called the dealer, he called into Mahindra tech service who told him that they have seen this in a few tractors. They suggested that we jack up the rear and look inside a shifter (tranny?) box for a loose 13mm bolt on the bottom. The boss and his son did this. I was not there to witness it (these descriptions are not mine), but he told me that the box was dry (looked like it was not a fluid containing area) and that they did not find a bolt bolt.
The dealer also said that Mahindra told them it could be an out of sync shifter rail which would could be fixed by welding a bead onto it in order to keep in track. I am not sure if this is something we can diagnose ourselves let alone repair.
I'll be at the farm tomorrow to have a look. Our dealer seems to be in over his head on this one and has to get back to Mahindra again. We need the tractor now and also don't want to have to rent a trailer and tow it 80 miles back to the dealer--if we can even get it onto the trailer--it's stuck in the field.
Has anyone here had a problem like this? What did you do to fix it. Or, if you have any good suggestions we are all ears.
No comments, anyone? Well, here's what happened. Our dealer followed up with Mahindra and drove out to us with a tech rep. They removed the transmission end of the shifter and replaced a rail. According to the owner who witnessed this, the new piece was of a different design than the original.
The dealer went to bat for him and, as I understand it, the factory is going to pick up the tab. So, thanks to Burright of Mt. Morris, IL we were back in business within 24 hours. How's that for service! :)
/ 7520 4wd stuck in neutral! #3
Glad to hear you're running again. Keep us updated on the progress...ie. if it happens again.....personnally, I believe the strongest type of shifter is directly over the gears (circa Mahindra 6000). even though the operators's platform is not "flat" like the 7520, much less can go wrong in the old style trans shifters. (just my $.02). BobG in VA
/ 7520 4wd stuck in neutral! #4
Sorry, didnt see your post or I would have said something altho Iv not had the problem on my '06 with 400hrs. Maybe they had upgraded already. What yr is yours?
Glad you got such quick and appropriate service. Mine has gone the whole range - spotty Id call it. There are still outstanding warranty issues dating from delivery. I repeatedly stir the pot, they acknowledge, and all goes quiet again.
larry
I'm not sure of the model year, the tractor is 2-3 years old.
Peter
/ 7520 4wd stuck in neutral! #6
Mike's a nice guy over there in IL. Glad he got you fixed up!
