750 John Deere
/ 750 John Deere #1
aau10
union grove, al
john deere
Can a bad voltage regulator cause the fuse link going to the starter to burn out?
/ 750 John Deere #2
Interesting question. Here's a what if....
Say the battery only charged to 8 volts, would the starter then try to draw 150% of its normal current and blow the fuse link? I don't know. More research on voltage/current relationship of dc motor required.
Edit: Maybe I have that inverted. It may be if the battery over charges to 18volts, then the starter would draw 150% of it's normal current.
/ 750 John Deere #4
I have never seen a voltage regulator blow the fusible link, but I guess it is possible. Usually a pinched or rubbed through wire somewhere is the culprit. Quite often I have seen mice chew through wires under the dash. They seem to like that area for some reason. Remove the panel around the key switch and look around.
/ 750 John Deere #5
I'd bet on the mice as well. I had to get my 750 rewired due to mice chewing the wiring harness. Tractor stays inside now.
/ 750 John Deere #6
I agree with jd110, I think you will find a pinched or bare wire shorted to ground.
2100 GAL WATER TANK (A68842)
2100 GAL WATER...
2003 Ford F-350 4x4 Crew Cab Flatbed Truck (A66736)
2003 Ford F-350...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
HEAVYEQUIPMENT HOSES (A68842)
HEAVYEQUIPMENT...
