750 John Deere
/ 750 John Deere #1
aau10
union grove, al
john deere
Can a bad voltage regulator cause the fuse link going to the starter to burn out?
/ 750 John Deere #2
Interesting question. Here's a what if....
Say the battery only charged to 8 volts, would the starter then try to draw 150% of its normal current and blow the fuse link? I don't know. More research on voltage/current relationship of dc motor required.
Edit: Maybe I have that inverted. It may be if the battery over charges to 18volts, then the starter would draw 150% of it's normal current.
/ 750 John Deere #4
I have never seen a voltage regulator blow the fusible link, but I guess it is possible. Usually a pinched or rubbed through wire somewhere is the culprit. Quite often I have seen mice chew through wires under the dash. They seem to like that area for some reason. Remove the panel around the key switch and look around.
/ 750 John Deere #5
I'd bet on the mice as well. I had to get my 750 rewired due to mice chewing the wiring harness. Tractor stays inside now.
/ 750 John Deere #6
I agree with jd110, I think you will find a pinched or bare wire shorted to ground.
23.1-26 Tires - Set of 2 (A68134)
23.1-26 Tires -...
2013 Toyota Sienna Van (A66738)
2013 Toyota Sienna...
ALLMAND MAXI-LITE II V-SERIES (INOPERABLE) (A68842)
ALLMAND MAXI-LITE...
2014 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2014 (INOPERABLE)...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2016 JCB 3CX 4x4 Loader Backhoe (A68183)
2016 JCB 3CX 4x4...
