Ballast 70 Lb Weights for 4300
/ 70 Lb Weights for 4300 #1
walls1
I was told by the local John Deere there are some new suitcase bumper weights for the 4300 that weigh 70 pounds each. The price was about $68.oo each. Does that price seem in line? Are these really new?
Thanks,
Bill Walls
/ 70 Lb Weights for 4300 #2
I just purchased new 80 lb. Kubota suitcase weights for $45 apeice. My weight bracket will carry 5 weights.
Will they fit my John Deere 4300 bumper without any kind of brackets?
Thanks,
Bill
/ 70 Lb Weights for 4300 #4
That $68. must be a catch all price... same for JD 99Lb front weights for the 5000 series...
/ 70 Lb Weights for 4300 #5
I am not sure what kind of weight bracket JD has for their 4000 series. I have a JD 5300 and the Kubota weights are greatly different. The kubota weights have a fairly long "tongue" on the front which I believe probably makes them fairly specific for a Kubota bracket. I also got the dealer to throw in a second weight bracket for free. (Most kubota's he sells have FEL. For the FEL to attach the weight bracket is removed and the loader mounting bracket is added. I bet he had 20-30 of these brackets.) The weights I bought were a little scratched and had slight surface rust. He also rents tractors and maybe he had used them before. I bought a can of Kubota gray paint, sprayed them, and now they look new. I modifed one bracket and mounted it on a 4"X6" angle iron. This goes over the existing FEL bracket and I use the removable loader pins to attach the angle iron. Quick on and off. (The loader has to be off to use the weight bracket) I use the 2nd bracket mounted to a 3pt. tow bracket. The 2nd bracket and weights can then be used as rear end ballast.
/ 70 Lb Weights for 4300 #6
The price I was quoted for the smaller 42lb weight was $30 or $.71 a lb. $68 for the 70lb weight works out to be $.97 a lb.
Round weight lifting plates with a center hole sell for $.45 a lb.
and on sale for $.35 a lb. You mount the weights on a rod or piece of pipe and use them either in the front or rear of your tractor.
/ 70 Lb Weights for 4300 #7
the 42# weights was that from JD was $30-32?
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
16ft. Field Cultivator (A65640)
16ft. Field...
KL480 Ventrac tiller
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
