Ballast 70 Lb Weights for 4300
/ 70 Lb Weights for 4300 #1
walls1
I was told by the local John Deere there are some new suitcase bumper weights for the 4300 that weigh 70 pounds each. The price was about $68.oo each. Does that price seem in line? Are these really new?
Thanks,
Bill Walls
/ 70 Lb Weights for 4300 #2
I just purchased new 80 lb. Kubota suitcase weights for $45 apeice. My weight bracket will carry 5 weights.
Will they fit my John Deere 4300 bumper without any kind of brackets?
Thanks,
Bill
/ 70 Lb Weights for 4300 #4
That $68. must be a catch all price... same for JD 99Lb front weights for the 5000 series...
/ 70 Lb Weights for 4300 #5
I am not sure what kind of weight bracket JD has for their 4000 series. I have a JD 5300 and the Kubota weights are greatly different. The kubota weights have a fairly long "tongue" on the front which I believe probably makes them fairly specific for a Kubota bracket. I also got the dealer to throw in a second weight bracket for free. (Most kubota's he sells have FEL. For the FEL to attach the weight bracket is removed and the loader mounting bracket is added. I bet he had 20-30 of these brackets.) The weights I bought were a little scratched and had slight surface rust. He also rents tractors and maybe he had used them before. I bought a can of Kubota gray paint, sprayed them, and now they look new. I modifed one bracket and mounted it on a 4"X6" angle iron. This goes over the existing FEL bracket and I use the removable loader pins to attach the angle iron. Quick on and off. (The loader has to be off to use the weight bracket) I use the 2nd bracket mounted to a 3pt. tow bracket. The 2nd bracket and weights can then be used as rear end ballast.
/ 70 Lb Weights for 4300 #6
The price I was quoted for the smaller 42lb weight was $30 or $.71 a lb. $68 for the 70lb weight works out to be $.97 a lb.
Round weight lifting plates with a center hole sell for $.45 a lb.
and on sale for $.35 a lb. You mount the weights on a rod or piece of pipe and use them either in the front or rear of your tractor.
/ 70 Lb Weights for 4300 #7
the 42# weights was that from JD was $30-32?
2003 GMC C4500 Crew Cab Dump (A62613)
2003 GMC C4500...
1991 Wilson Hopper Bottom Trailer (A66285)
1991 Wilson Hopper...
12' x 76" Tilt Trailer (A66285)
12' x 76" Tilt...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
2008 Chevy Trail Blazer (A62679)
2008 Chevy Trail...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
