7 Foot Bush Hog
   / 7 Foot Bush Hog #11
Sold it and bought a dual spindle 8 ft Landpride. Cant tell the 8 pulls any harder than the 7 did. its just not as long.
That's what I've always heard as well.
   / 7 Foot Bush Hog #12
I run this 72 inch Woods,
mostly on a good strong 45 pto hp farm tractor and in heavy grass it's a big load, so I also don't think I'd want a 7 footer on a 43hp tractor...
BTW, that Woods medium rotary cutter has a 115 hp gear box and it's as good or better than any cutter in it's price range! I consider it a better cutter than a Bush Hog or the other common brands in medium duty......
SR
   / 7 Foot Bush Hog #13
with a 45 hp tractor and an 8 ft twin blade my 6 footer sits idle. get a 6 and you will always wish for the 8.
   / 7 Foot Bush Hog #14
I run a 7 bft woods rotary cutter behind a mf 255 , the tractor handles it fine even through tall thich stuff. but it is a lot of length sticking out. i wish i had a dual spindle 8 ft. I also run a 6 ft standard duty behind a 38 hp mahindra cutting 5 ft brush no problem.
   / 7 Foot Bush Hog #15
I have a Hardee with two tailwheels. I didn't shop brands, but this one looked okay at a dealer I liked. I fabbed a door on the back of the deck that I can open to sharpen the blades. With the twin tailwheels, and sharp blades, it will cut almost equal to a finish mower. I wanted one that was a little wider than the rear wheels, for trimming the fenceline, and trails. The twin rear wheels cut down a Lot on scalping.
It's their medium duty cutter, but has the heavy duty gearbox. It's over 20 years old, and has been great.
I keep a 40 gallon tank welded on it, with two pumps. One pump is for the "boomless" boom on the back, that can cover a 30' swath, and the other pump is a higher pressure, but lower flow, for a wand that I keep up by the seat. I have to open a ball valve to use the boom, but the wand can be used with a flip of a switch on the dash for spot spraying.
   / 7 Foot Bush Hog #16
Brushhog brand makes a 7ft called a squealer it is 7ft wide but only 5 ft long weighs about the same as a 5ft.it has 2 spendals a total of 4 blades mine is offset to the right about a foot its designed for 30 to 40 hp tractors I love mine it works great
   / 7 Foot Bush Hog #17
Have a 7' LMC med duty, grass & weeds around the yard are easy to keep trimmed with it. Big thick stuff does not mow well unless going slow.
Got a MX10 last year to speed up keeping trimmed around planted fields & brush cutting in edg of fields. Does not work around the yard.
Either one on 8560 Mahindra but 35hp tractor is a yard mowing machine with LMC 7 footer.20190902_190343.jpeg20170519_191855.jpeg
   / 7 Foot Bush Hog #18
Sounds to me you need to do some work clearing things your just destroying your brushhog use some common sense man
   / 7 Foot Bush Hog #20
You mean you aren't suppose to run over and hog out stuff like this?
OR like this clearing i'm putting through here,
Or here?
I thought that was what they were for!
SR
544 (A52708)
544 (A52708)
BUSH HOG 14' ROTARY MOWER (A52708)
BUSH HOG 14'...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLET OF TILE & SUPPLIES (A58374)
PALLET OF TILE &...
(NEW) EXPEDITION 370 CROSS BOW (A58374)
(NEW) EXPEDITION...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
