7" angle grinder
/ 7" angle grinder #41
thinking about it, maybe a 7" grinder would have worked well on the tusk/tooth extraction rather than pliers and a hammer !!!!
/ 7" angle grinder #42
Has anyone ever used the replacement brushes that come with the power tools? If I have, it was only one time and I don't remember for sure.
I've replaced brushes in Milwaukee 4.5" grinders, Drills and Worm gear saws. It's nice to be able to do that But.. The new cordless-brushless tools are amazing.
/ 7" angle grinder #45
They neet to come out with a real 7 0r 9 AC brushless.
The small frame ac brushless seem nice
/ 7" angle grinder #46
Got a 7 inch Milwaukee in 2005 primarily for the extended reach over a 4.5. Gets into deeper corners/cuts deeper than the smaller diameter wheels.. That said, I make a mental note to concentrate hard when using the thing. The starting torque is significant (compared to the smaller ones) and if the optional hand grip is not attached, thing want to twist in your hands. Everything else is also magnified, so if it binds and kickbacks, it pays to be on your toes. If you like running these with the guards removed, pay particular attention.
Thing has some heft to it, will build up your forearms with repetitive use. Any position other than horizontal is a workout, at least for this old guy. I use it, but not nearly as often as I thought when purchased.
/ 7" angle grinder #47
The 9" I have has "soft start" - it's a nice feature for sure with a 15 amp motor.
It's fairly heavy, flat position grinding is its preferred use :D
/ 7" angle grinder #48
Horse power, if reported accurately would be a terrific figure of merit for rating/comparing grinders and such. Amps alone represents a questionable figure of merit as it does not take into consideration efficiency. A very inefficient tool might use lots of amps but much of the power consumed could be going to heat, not torque. You might have noticed really cheap poor tools often run hotter than high quality tools. That is more electrical energy going to heat than useful work as compared to the high quality tool.
/ 7" angle grinder #49
Good point!
/ 7" angle grinder #50
My old 7' angle grinder finally died after many years of good service and a replacement is needed. What brand/model/features do you like? I have a 4 1/2 inch one, but need the bigger model. What do you have?
All mine are HF and are super products for the price. I like the 4 ス grinders running 4 amps which have a really attractive price. I have their 9" and it's a beast. 7 would be a good size for larger jobs as the beast is just that. However, for most jobs the 4 ス does the job...I have 4, 2 older ones and 2 newer ones, all still working. 2 have grinding wheels, one regular grinder and the other something new that is a series of strips of abrasive glued around in a circle for knocking rust off things you don't want to cut into, one with a cutter wheel, and the last with a wire brush. For dressing mower blades they can't be beat and on my shredder, i just lift up the shredder, roll the blade around to where I can get to it from the rear and in a flash ready to go.
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2018 John Deere TX (A53317)
2018 John Deere TX...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
