7" angle grinder
/ 7" angle grinder #21
I'm quite the amateur and I'm wondering at what the 7" (and 9"!) grinders are typically used for.
I've got three 4 1/2" grinders that get a lot of use, but I've never been exposed to a 7" and I tend to make do with what I've got unless it flat-out doesn't do the job, or someone educates me, and since my old mentor-neighbor died a while back, I don't get much of an education other than what I get off the web.
So, web, tell me why I need a 7" :)
/ 7" angle grinder #22
How much material u want to remove and how much power u need are some good reasons for going from a 4 1/2 " grinder to a 9". 41/2 are usually 4 or 5 amp 9 " are 15 amp . Go on the metabo website and look how many grinders they make ranging from lite duty 7 amp to 14 amp .In all sizes 4 - 9 , you wouldn't want to use a 14 amp 5 " grinder made for concrete diamond wheels to remove rust or paint all day . The weight difference is a few pounds between 7 amp and 14 amp. If u put a diamond wheel in a 4 1/2 " 7 amp grinder and tried to cut concrete it wouldn't last a day. Match grinder power to job. :drink:
/ 7" angle grinder #23
I'm not sure exactly how they were used, but the Sioux tools I dealt with were very old and were used by one of major trucking company's "trailer rebuild shop".
/ 7" angle grinder
No real agreement here. But I've used a lot of Dewalt stuff and had good service. Lookin' at model DW840 I think. I also have several Bosch tools, like a sawz-all, that has gone above and beyond. Lookin at model 1974-8. About a $60 price difference. Mostly used on old broken farm equipment farm equipment.
/ 7" angle grinder #25
I got my 9" HF to finish a cut through concrete that was thicker than expected. Didnt want to rent a real concrete saw & needed the bigger blade for an inch or 2 more cutting than what I got out of the diamond blade on the circular saw.
Use it for bigger grinding jobs on steel mostly now.
/ 7" angle grinder #26
I don't actually use the big grinder for that much metalworking. 9" diamond blade is terrifying but works well for cutting concrete and rock.
Put a sanding disc on it for fast wood removal sanding in rustic carpentry. Belt sander can't compare. Belt Gives cleaner results but three days into sanding a new cabin out in the woods you might reach for the disc.
And sometimes with metal, for big metal or a lot of metal or a lot of grinding, the bigger tool is faster and takes the abuse better.
I have a DeWalt 9", put 7" on it sometimes. 9" is lower rpms so better for sanding wood and the bigger blade capacity is good for concrete. Works well, good quality so far.
/ 7" angle grinder #29
Got a Milwaukee that has ground a LOT of concrete floors the last couple of years and a fair bit of metal. Holding up nicely.
Dewalt would be my second choice of brands.
Matebo, Bosch, Mikita all are known good brands
/ 7" angle grinder #30
Has anyone ever used the replacement brushes that come with the power tools? If I have, it was only one time and I don't remember for sure.
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
International 9200 (A61307)
International 9200...
Location Info Please
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 FORD F-600 SERVICE TRUCK (A60736)
2020 FORD F-600...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
