Mid-Mount Mower 650 belly mower
/ 650 belly mower #1
Jordonmj
Jackson, mi
JD 755
Hello,
I bought this belly mower for my JD 755 and the pto faces forward. My thought was to turn around the gear box or replace it with the right one. It is in excellent condition. I would consider selling it if this does not work. Thanks for your input.
OM-M72244 160 Rotary Mower is what is on the manual. I also have the rear brackets to hook it up to trailing arms.
/ 650 belly mower
I am assuming no one has tried to convert this mower to work on a 755.
/ 650 belly mower #3
I did something similar at one time but I made it 3pt. Issue I had was it turned backwards. Changed blades to left hand ones and it worked on the deck (think it was gravely) I used. By changing the blades you could have a issue the way the grass is discharged. Just a thought for you.
/ 650 belly mower #4
The front PTO on the 650/750 wasn't 540rpm. 1000rpm? not sure. I don't think that's going to be cost effective for you.
/ 650 belly mower #5
Yea you're probably right. You got me thinking now that maybe the front mount was engine rpm. That makes it even faster ?
/ 650 belly mower
so what I am hearing is the rpm will be way to high once hooked up to the rear pto or to low??????
(6) 8" X 8" TREATED TIMBERS (A63291)
(6) 8" X 8"...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2019 Terra Gator TG8400 Spreader (A63111)
2019 Terra Gator...
2022 EZ-GO ELITE...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
