Pharmboy
6410 forward / reverse lever no engaging tractor into forward.
Reverse works
Reverse works
:welcome: to TBN
Can you give us a better description of what the history is of your tractor, and what led up to the reverse not working?
Help us out a bit here...
Have you looked at the linkage?
iit see
It is an electonic switch and apparently involves wiring and a relay etc. There was no warning other than an hour before (while feeding) it quit and then worked. The f/r lever ( on the left of the steering colum) does feel looser, and more warn than one would remember fron 3 or 4000 hours ago.
thank you for all your help
The diagnostic manual is TM4572 and the repair manual is TM4574. Do you have mfwd? If so, check clutch pressures with mfwd turned on and off to see if there is any difference. Also try with pto turned on and off.
