6410 not engaging in forward gear
   / 6410 not engaging in forward gear #1
Pharmboy
100 mile house BC
John Deere
6410 forward / reverse lever no engaging tractor into forward.
Reverse works
   / 6410 not engaging in forward gear #2
:welcome: to TBN
Can you give us a better description of what the history is of your tractor, and what led up to the reverse not working?
Help us out a bit here...
Have you looked at the linkage?
   / 6410 not engaging in forward gear #3
:welcome:
To the forum from Alabama.
   / 6410 not engaging in forward gear #4
Sounds like you have a Power Reverser. Is it mechanically or electrically operated?
:(iit see
:welcome: to TBN
It is an electonic switch and apparently involves wiring and a relay etc. There was no warning other than an hour before (while feeding) it quit and then worked. The f/r lever ( on the left of the steering colum) does feel looser, and more warn than one would remember fron 3 or 4000 hours ago.
   / 6410 not engaging in forward gear #6
A cab tractor?
Might be a good time to get the service tech manual so you can check out the function of the switch, wiring and relay that might be involved.
Looking at jdparts, it appears (tho I admit I do not know for sure) it might be a control module that has lever and internal switch.
But others may be able to offer more help here.
A pic of the apparent problem area might help some. Specific model of the 6410 may also help to track it down.
   / 6410 not engaging in forward gear #7
:(iit see
I does sound like a wornout lever/switch.
   / 6410 not engaging in forward gear #8
When you engage forward, does the lever stay in the forward slot or does it fall back to neutral? If it falls back, have you tried to hold it in forward to see if it will move?
   / 6410 not engaging in forward gear #9
i have a 6415 with power quad transmission
if has left hand reverser
the reverser is manual and does not have fwd and rev electric solenoids
the transmission pressure is 200 psi and i have a gage on it, it has good pressure at 1400 rpm
runs the tractor for about 40 minutes and it will warm up and loose pressure in fwd direction shift to neutral and the rev it will back up
it only stops pulling in fwd direction
i have pulled the 3 relief valve and the all look good
i pulled the fwd and rev manual valves they all look good
i pulled the cooling oil and clutch cooling valve and it looks ok
i also pulled the valve that the left hand reverser moves and it all looked good with no issues
i would appreciate any help greatly
thanks
   / 6410 not engaging in forward gear #10
Sounds like the forward clutch is leaking.
I am guessing there are ports labeled clutch for Forward, and brake for Reverse. Check pressures at the these ports.
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
Fifth wheel multi use trailer. (A53472)
Fifth wheel multi...
HAMM HD+ 120I DOUBLE DRUM ROLLER (A51246)
HAMM HD+ 120I...
UNUSED MOWER KING ECSSCT72-72" HYD TRENCHER (A51248)
UNUSED MOWER KING...
