62D Wheel Fix
/ 62D Wheel Fix #1
tb1472000
Indianapolis Indiana
JD2520
For those of you that had the problem with the wheels digging ruts on the 2520, did it cost you anything to get it fixed? My dealer wants about $160 to replace the wheels. The tractor is still on warrantee and I bought the extended warrantee and maintenance plan if it makes a difference.
Thanks,
Bruce
/ 62D Wheel Fix #4
If you have a stuborn dealer you may have to make a call to JD customer service to get a little help.
/ 62D Wheel Fix #5
You could always do it yourself for the cost of a drill bit, tap set and 2 zerks. I was a little leary of "carving up" my deck, but my dealer has been very little help on other issues. It works/looks great and from what I have heard here, it's how the engineers have handled it on the *new* model 62D. I agree it's something that should have been factory/dealer fixed considering the $ involved, but in my world necessity is the mother of invention. Let me know if you want any more details about this diy fix.
/ 62D Wheel Fix #6
I got my wheels for free from my JD dealer. I never asked him to install them I just installed them myself and drilled and tapped for the zerks myself. The only thing additional I did was to grind a groove in the shaft so the grease going into the zerks has a place to go. This made a huge difference in getting enough grease inside and having it stay there. Took me two hours to do the whole thing which included replacing all four wheels.
/ 62D Wheel Fix #7
Great idea! The wheels on my deck don't seem to have a problem with holding grease, but the pivot shaft on the two front wheels never seems to get grease properly. Where they put the Zerk, all the grease goes down, and none goes up. I may cut a grove in the shaft and see if that helps.
Thanks for the idea!
/ 62D Wheel Fix #8
Here's what I did. You just need to scribe a line around the shaft at the location of the zerk. then I used the corner of my bench grinder wheel to simply grind a shallow groove around the shaft at that location. My wheels pivoted even better after doing this than after installing the zerk with no groove. I tried it both ways.
/ 62D Wheel Fix #9
Thanks BX1. How old was your deck that it didn't come with the wheels that swiveled and had Zerk's? My deck is a little over a year old and it came with swiveling wheels plus Zerk's in each wheel and the swivel joint.
/ 62D Wheel Fix #10
BigD9, I just got my tractor this spring but apparently my dealer had a late 2006 deck that he sold me. The wheels are mounted on needle bearings and do have grease fittings. The pivot did not have grease zerks. I wasn't too happy when I found out that after ordering a "new" tractor I got an "old" deck but he promptly ordered the new wheels as soon as I told him that I learned on this forum that they were available. He normally does not sell small tractors so he doesn't usually know a lot about them. But his prices are right. I offered to install the wheels myself and thereby was able to keep my old wheels as well. Even though they are a different shape I'll keep them for spares and/or use them on some other project some day. I think they are expensive wheels. So I'm curious, even though you have a deck that came with zerks there are no grooves to channel the grease around? The groove might be in the bushing rather than the shaft. That would be the best place to put it in order to not weaken the shaft with a groove. It would have been hard for me to put a groove on the female bushing so I just but a very shallow one on the shaft. It really made the grease go in easy and definitely improved the pivot of the wheels. Good luck with yours.
/ 62D Wheel Fix #11
Didn't know they changed the shape of the wheels also. I know when I ordered my tractor, the deck was the holdup in delivery. Everything else was sitting on the dealers lot. He called me and since I was working 800 miles from home at the time, I told him to just wait till the deck arrived before delivering the complete tractor. So I guess I got the most updated deck.
Don't know about the groove in the shaft or bushing. I had it apart once when the shaft was very hard to turn/swivel, and removed some polypropylene twine (this place is loaded with old twine embedded in the ground left over from feeding bales of hay to the former residents) but I didn't think to look for grooves. Will do next time.
Thanks for the tip.
/ 62D Wheel Fix #12
BZ1, I got a chance today to look at that front wheel swivel shaft. The shaft is solid with no grooves. The bushing is a white plastic material. The Zerk is located in the top third of the shaft. Thats why all the grease comes out the top. I was getting ready to cut a grove in the shaft when my better half wanted the mower.
I'll put this modification on my to do list for this winter.
/ 62D Wheel Fix #13
BigD9, for better or worse I put my zerk in the middle of the shaft/bearing. With the goove in place the grease pretty much goes all the way around and comes out the top and bottom all the way around. It works.
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
HEIN-WERNER 57 SERIES 2 BUMPER JACK (A65643)
HEIN-WERNER 57...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
2020 John Deere 6120M (A62180)
2020 John Deere...
