Oil & Fuel 6284 Engine Oil
/ 6284 Engine Oil #1
gfreek
Service manual says engine takes 5 qts, but the dipstick shows full at 3 qt. & I drained 3 qts. Anyone know what the deal is on this? Engine is a 28 hp Cat/ Perkins.
/ 6284 Engine Oil #2
Probably a dumb question but did you start it to fill the filter?
/ 6284 Engine Oil
Yup , actually I put 4 qts in & new filter , started it, shut it down and then checked it, and it was over, so I measured what I drained, 3 qt's.
/ 6284 Engine Oil #4
I ran into the same problem. On page 26 of the manual under Lubrication Table it lists the engine oil capacity as approx 5 qts w/filter. When I changed my oil and filter I put in 5 qts of fresh oil, started the engine for a few moments, shut it off, and checked the oil level on the dipstick. The dipstick showed that the oil was considerably over the full mark. So I went searching in the manual and found the following on page 45 of the manual under Specifications - engine case capacity (with filter) it lists minimum 3.6 qts (3.4 L) to maximum 5.2 qts (4.9 L).
Either the manual is not correct when it says 5 qts or the wrong dipstick is in the engine. The manual warns against overfilling so I drained out about 3/4 qt of oil to bring the level on the dipstick to the full mark. Judging from the physical size and appearance of the oil pan I think that around a 4 qt capacity seems more believable than 5 qts so from now on I plan to fill the engine with 3 qts and then check the dipstick and add until it shows at the full mark.
If would be nice if someone could clarify this since I don't want to either run the engine too full or low on oil.
JN
/ 6284 Engine Oil #5
I have a 2006 6284 and looked at a parts cross reference list and for the oil filter 150-4140 that is on my tractor it stated that a Fram PH-16 could be used. Wrong. The PH-16 is to big on the outside diameter. Can anyone tell me if there is an aftermarket oil filter for my Cat engine that I can maybe get locally at Wally World or an auto parts store?
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
2018 KMC 4505 (A64126)
