6210 Won't Start
/ 6210 Won't Start #1
Believer
My 6210 has always started right up. Has been parked for a couple weeks and now won't start, doesn't fire at all. Must not be getting fuel. Checked all the wiring for rat chewing and everything looks fine. What should I do to check if I'm getting fuel where it's needed? Thanks
/ 6210 Won't Start #2
Need to make sure your getting power to transfer pump and see if it's working.
/ 6210 Won't Start #3
I've had some have a air lock drawn into supply line between tank and main filter.
/ 6210 Won't Start
Thanks for replies. How would I determine if the transfer pump is working? How would I remedy an air lock?
/ 6210 Won't Start #5
When you turn the key on, you should hear the electric transfer pump in the tank humming. Try loosening the bleed screw on the fuel filter with key on and see if fuel squirts out. If it does, then follow the fuel line from the filter to the injection pump. Loosen the fitting at the pump with key on until you get good fuel flow. Then loosen a couple of fuel lines leading to the injectors and crank engine and see if you get any fuel. If you do, tighten the fittings and crank some more. Engine should start. SOunds like the fuel may have drained back while sitting. Actually before you do all that, I should have said to check for 12 volts going to the fuel shut off solenoid on the pump. If not then check for blown fuses.
/ 6210 Won't Start #6
Yes what jd110 has stated. I've had a similar issue and had to install a check valve so the supply line would not bleed back to take. Keeping it primed and air out of system
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2018 SKYJACK  SJ843TH (A67714)
2018 SKYJACK...
DYNAPAC CP-2700 PNEUMATIC ROLLER(INOPERABLE) (A67714)
DYNAPAC CP-2700...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
PORTA POTTY (A67714)
