6210 Fuel Pump, No Power
/ 6210 Fuel Pump, No Power #1
Believer
On 6210, won't start. I have no 12v to fuel pump. I understand the red to black wires at connector are power to pump. I have connector disconnected from pump. Switch turned on of course. Checked fuse, 30 amp. I can't trace out the wires. Don't know what to do next, any help would be appreciated.
I figured out a little more. I knew the pump was supposed to come on during run so I found the red pump wire at the switch. I AM getting 12v at the pump (red wire) to ground....but not to to the black wire with switch to RUN. I'm assuming the black wire is supposed to go to ground but I do not have continuity of the black wire to ground. Can anyone tell me if the black wire is supposed to be ground? I'm about ready to tie it to fround.
/ 6210 Fuel Pump, No Power #3
Yes the black wire is the ground wire.
So I connected the black wire to ground at the pump connector and pump works.
