Mark @ Everlast
Advertiser
6013 is has good ductility. Its a fast fill rod and works great on sheet metal, and anything in general. Some people call it the "sheet metal rod". Its a fine rod for build up and general repair. Its not for bridges, but holds great for welding up to 3/8" steel. For the application, and the price, there is NO better rod. It will weld AC or DC btw.
7018 rods are fine for general repair even if they aren't "heated". Not much concern about underbead cracking on sheet metal.
But anything to code should be dry and hot. 6011's work well and are a general "farm" rod. The arc is stable and the rod is fairly easy to use and can even pass for 6010 work when called upon. Farmers are a little lazy when it comes to cleaning a weld properly and is probably why so many are sold. 6010's are just cantankerous enough not to be everyone's cup of tea. Hard starts and sticking are common complaints even with moderately experienced welders. They have penetration and are the standard for root pass welding, but 7018's are what show on top, with the 6010 usually being backgouged to a razor thin layer. Some 6010 is done all the way out...But What I think I see developing here in this discussion is a matter of personal experience, preference and regional practices, not necessarily world wide standards. There are plenty of "books" and literature that discuss the primary application of all these rods. Its easy enough to confirm what is right and standard for use.
