6000 vs. 6000 4wd
/ 6000 vs. 6000 4wd #1
timberfarmer
Tuscaloosa AL
Mahindra 6000 & Zetor 4341
I am considering purchase of a 6000 2wd or 6000 4wd. I already have 1 4wd tractor. What would be the pros and cons of purchasing a 2wd vs. 4wd for use on a fairly level farm. What should the cost differential be. Thanks /forums/images/graemlins/confused.gif
/ 6000 vs. 6000 4wd #2
Uses are usually necessary prior to getting informed opinions. If you are going to pull wagons only or dig ditches.....Don't mean to be mean but let us know what it is you intend to do. BobG in VA
/ 6000 vs. 6000 4wd
Will use as a backup for cultipacker 1500 lbs., 7 ft Alamo cutter, box blade, disc, cutting firelanes, road maintenance. Planting wildlife fields, and discing. Probably will use 100 hrs/year. It may sound silly, but I would like to keep the cutter hooked up to one tractor at all times because it is the greatest use. When I'm at the farm alone it is hard to change implements.
/ 6000 vs. 6000 4wd #4
Sounds like you could get by easily with 2wd. I think the last time I checked, the difference in price is about $2K or so (I'm not really sure on this). If you dont' want an FEL go with the 2 Wd. If you get the FEL, suggest go also with the 4WD. My 6000 4WD is a beast (am still having problems with Mahindra on the BH but wouldn't get rid of the tractor.....)Whatever you get load the rear tires.....Good luck!! It's a great tractor for the money. BobG in VA
2011 FORD F-550 CAB AND CHASSIS(INOPERABLE) (A65643)
2011 FORD F-550...
2015 Ram 4500 Service Truck, VIN # 3C7WRKAJ9FG707673 (A65563)
2015 Ram 4500...
2015 Chevrolet Express Van (A62613)
2015 Chevrolet...
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
STORAGE FEES (A59914)
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
