60" or 72" ????
/ 60" or 72" ???? #1
Hoosier3030
Norhern Indiana
B3030
60\" or 72\" ????
I am in the market for the Kubota belly mower that I will run on my B3030. Has anyone had direct experience with the 60" and 72" decks? My dealership keeps pushing the 60" because they do a better job; according to them. I have mowed my 3 acres w/ my uncles 2910 that has the 72" deck and I did not seem to have any problems with scalping, etc.. It seems that the wider would be better in most cases; plus it sticks out further than the 60" which allows you to get closer to obstacles. Im kinda leaning towards the 72" unless I am missing something else. Any suggestions, recomendations?
/ 60" or 72" ????
60\" or 72\" ????
/ 60" or 72" ???? #3
Re: 60\" or 72\" ????
I have the 72" on my B3030HSDC and it works just fine. I am impressed with the job it did for me. No scalping. /forums/images/graemlins/smile.gif
/ 60" or 72" ???? #4
/ 60" or 72" ???? #5
I have the 72" on my B2630 and it works great. I have has some scalping in the most uneven areas of my lawn. Raising the setting to 3 1/2 inches was enough to cure it. I chose the 72 because it hangs out beyond the tires. The 60 was too narrow for the tractor.
/ 60" or 72" ???? #6
/ 60" or 72" ???? #7
I'm running the 72" on an L3130 and have no performance issues. If I had it to do over, I'd attach the mower to the three point hitch. I hate taking the mower on and off, which has to be done for its maintenance and if I want to use any other attachment (including serious use of the loader). You lose some manueverability, but you'll cuss a lot less laying under the tractor trying to attach the mid PTO shaft.
/ 60" or 72" ???? #8
/ 60" or 72" ???? #9
I had the same question when I bought my B3030. Finally I got a 60". No scalping for sure. I have some uneven spots and it does an excellent job. If, for any reason, you want to add a bagger one day, you can do it with a 60" not with a 72". If you want to do some job with a FEL with the belly mower mounted on it's easier in tight spots.
I guess the two most important questions are: What kind of terrain do you have (even or not)? Do you want a bagger or not? Flat land and no bagger would probably be a 72".
/ 60" or 72" ???? #10
/ 60" or 72" ????
Really? You can only get a bagger for the 60" deck? I did not know this. I did have thoughts of a bagger some day. Thanks for the info. My terrain is mostly flat with gently rolling hills; I was really counting on the 72", but with no bagger I will have to ponder this one.....
/ 60" or 72" ????
/ 60" or 72" ???? #13
I've been told by a few different dealers & owners that the 72" can be a little unwieldy, can scalp (as others have pointed out) and in some cases you can actually make the same or better time with the 60". Plus, the 72" is at least $500 more, so you have to ask yourself if 12" and extra weight is worth it. I was surprised to see a majority of 72" owners in the replies because the dealers told me they rarely sell any. I would suspect that makes replacement parts more expensive too. To not just want to sell me the bigger more $$$ deck implies candid and honest remarks. Fwiw, myself, I'm planning on getting the 60" on a B3030. I also have a fair amount of crap to mow around, so the lack of total wide open spaces means the 72" might not reach full potential for me. No offense to the Six-Footers out there, just what I've been told/figured was best for me.
/ 60" or 72" ???? #14
/ 60" or 72" ???? #15
The biggest advantage of the 72" MMM is that the deck sticks out an additional 6". This allows you to get under and closer than the 60". Rear tire width with turf tires on a B3030 is 56". That only leaves 1 1/2" of cutting on each side of tractor. I have a 72" MMM on my B2910.
/ 60" or 72" ???? #16
/ 60" or 72" ???? #17
I've had the 60" and have the 72". They both do a fine job. The only negative comment i can make is the 72" is a little more likely to scalp on uneven surfaces but it's easy to control once i became aware of the problem.
/ 60" or 72" ???? #18
/ 60" or 72" ???? #19
I have the 60" MMM on my B3030. It runs about even with the right side of the tractor and sticks out about 5"s on the left. It does work great for trimming though because on an inside turn to the right, the mower will follow the track of the left front wheel. That means that you can drive right next to something with the left front wheel and even in a full lock turn the mower will cut right up that point. The 72" probably will do that as well, but I am just pointing out that the 60" works fine for trimming around flower beds, walls, trees, etc.
After I had the 60" MMM for a while I thought about trading it in for a 72". I finally decided to keep the 60" since a 72" would be too big for my Vac system, which I converted from a 50" mower on my JD. I also thought that the 72" was "drive over" only. Reading some of the posts on this thread seems to indicate that it will roll out and under the tratctor as well. If it is drive over only then it would not be as handy for me since when I remove the mower I just roll it under my boat which is parked next the tractor in my my barn. A drive over only deck would require it's own storage area.
I am sure either deck will be fine. I am happy though with the 60". It does a great mowing job for me.
/ 60" or 72" ???? #20
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
Butler MFG Water Tanker (A63688)
Butler MFG Water...
Polaris Ranger 1000 (A64127)
Polaris Ranger...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
38" FIRE PIT RING/DISK (A64281)
38" FIRE PIT...
