5530 wont start
/ 5530 wont start #1
Redman1989
Mahindra 5530
I have a 08 5530. It shut off like you turned key off. I went thru fuel lines,changed filter, bled all way to injectors. Had fuel. Took fuel shutoff out and tested. It moves in and out fine. Squirted 1 shot of either,which I hate, and it started. Can't find real problem. Will not start. It's like it's electrical. What can it.be?
/ 5530 wont start #2
There is likely a fuse specifically for the fuel shutoff solenoid. You say you removed and tested the solenoid, but what about its installed operation? I've never tested one in or out of a tractor.
/ 5530 wont start
I checked voltage to it. It had about11 volts going to it. I took it out and grounded it. It moved in and out when I turned key off and on.
/ 5530 wont start #4
Is there just one wire on the solenoid? If so, it should only power up to turn the tractor off. If you have voltage all the time you could have a stuck relay. If this is the case you could remove the wire and see if it will start.
/ 5530 wont start
Only has power when you turn key on.
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2023 Deere 325G (A60462)
2023 Deere 325G...
KBH Tender Trailer (A63118)
KBH Tender Trailer...
UNUSED GIYI CW59-59" COMPACTION WHEEL (A62130)
UNUSED GIYI...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2007 Blue Bird All American/All Canadian Bus (A61568)
2007 Blue Bird All...
