5530 wont start
/ 5530 wont start #1
Redman1989
Mahindra 5530
I have a 08 5530. It shut off like you turned key off. I went thru fuel lines,changed filter, bled all way to injectors. Had fuel. Took fuel shutoff out and tested. It moves in and out fine. Squirted 1 shot of either,which I hate, and it started. Can't find real problem. Will not start. It's like it's electrical. What can it.be?
/ 5530 wont start #2
There is likely a fuse specifically for the fuel shutoff solenoid. You say you removed and tested the solenoid, but what about its installed operation? I've never tested one in or out of a tractor.
/ 5530 wont start
I checked voltage to it. It had about11 volts going to it. I took it out and grounded it. It moved in and out when I turned key off and on.
/ 5530 wont start #4
Is there just one wire on the solenoid? If so, it should only power up to turn the tractor off. If you have voltage all the time you could have a stuck relay. If this is the case you could remove the wire and see if it will start.
/ 5530 wont start
Only has power when you turn key on.
2018 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2018 Ford F-550...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
JOHN DEERE 1790 - 12R30" / 23R15" VACUUM PLANTER (A64278)
JOHN DEERE 1790 -...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
Bear Statue (A64557)
