5530 wont start
/ 5530 wont start #1
Redman1989
Mahindra 5530
I have a 08 5530. It shut off like you turned key off. I went thru fuel lines,changed filter, bled all way to injectors. Had fuel. Took fuel shutoff out and tested. It moves in and out fine. Squirted 1 shot of either,which I hate, and it started. Can't find real problem. Will not start. It's like it's electrical. What can it.be?
/ 5530 wont start #2
There is likely a fuse specifically for the fuel shutoff solenoid. You say you removed and tested the solenoid, but what about its installed operation? I've never tested one in or out of a tractor.
/ 5530 wont start
I checked voltage to it. It had about11 volts going to it. I took it out and grounded it. It moved in and out when I turned key off and on.
/ 5530 wont start #4
Is there just one wire on the solenoid? If so, it should only power up to turn the tractor off. If you have voltage all the time you could have a stuck relay. If this is the case you could remove the wire and see if it will start.
/ 5530 wont start
Only has power when you turn key on.
2024 HAMM HTC-15 TRENCH COMPACTOR (A64278)
2024 HAMM HTC-15...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A64553)
2025 GIYI GY-PG72C...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
3PT POST HOLE DIGGER (A64278)
3PT POST HOLE...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
SHOPBUILT T/A TRAILER (A64278)
SHOPBUILT T/A...
