5525 Hand Throttle
/ 5525 Hand Throttle #1
DB KANSAS
Wichita, KS
Last week I did some mowing a mile from our farm and of course used the foot throttle to drive back. When I got back the hand throttle was not working. It will move like normal but is not doing anything. Anyone had this issue before? Easy fix?
/ 5525 Hand Throttle #2
All you can do is check all of the throttle linkages on the hand throttle and make sure a link hasn't come apart. Good luck with it.
/ 5525 Hand Throttle #3
Had this happen on our 5530wd turbo, Check the linkage and you will probaly find a missing pin on the linkage next to the engine block on the left side - (clutch side). It takes a very small cotter pin to keep the pin in place - weak cotter pin. Not the easiest to replace use a needle nose pliers and patience.
/ 5525 Hand Throttle #4
The nut that ties the cable to the throttle on the engine could gave come off... This happed to a 6025 I had....
Thanks for the help. It will probably be this weekend before I can get out there to figure it out.
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2020 CATERPILLAR...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
LOT OF YETTER SHARK TOOTH TRASH WHEEL UNIT MOUNTED (A64278)
LOT OF YETTER...
