5525 Hand Throttle
/ 5525 Hand Throttle #1
DB KANSAS
Wichita, KS
Last week I did some mowing a mile from our farm and of course used the foot throttle to drive back. When I got back the hand throttle was not working. It will move like normal but is not doing anything. Anyone had this issue before? Easy fix?
/ 5525 Hand Throttle #2
All you can do is check all of the throttle linkages on the hand throttle and make sure a link hasn't come apart. Good luck with it.
/ 5525 Hand Throttle #3
Had this happen on our 5530wd turbo, Check the linkage and you will probaly find a missing pin on the linkage next to the engine block on the left side - (clutch side). It takes a very small cotter pin to keep the pin in place - weak cotter pin. Not the easiest to replace use a needle nose pliers and patience.
/ 5525 Hand Throttle #4
The nut that ties the cable to the throttle on the engine could gave come off... This happed to a 6025 I had....
Thanks for the help. It will probably be this weekend before I can get out there to figure it out.
2011 International DuraStar 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2011 International...
2014 KAWASAKI KAF400B (A66091)
2014 KAWASAKI...
KL480 Ventrac tiller
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2022 Ford F-150...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2015 Jeep Renegade Latitude SUV (A64557)
2015 Jeep Renegade...
