5525 Hand Throttle
/ 5525 Hand Throttle #1
DB KANSAS
Wichita, KS
Last week I did some mowing a mile from our farm and of course used the foot throttle to drive back. When I got back the hand throttle was not working. It will move like normal but is not doing anything. Anyone had this issue before? Easy fix?
/ 5525 Hand Throttle #2
All you can do is check all of the throttle linkages on the hand throttle and make sure a link hasn't come apart. Good luck with it.
/ 5525 Hand Throttle #3
Had this happen on our 5530wd turbo, Check the linkage and you will probaly find a missing pin on the linkage next to the engine block on the left side - (clutch side). It takes a very small cotter pin to keep the pin in place - weak cotter pin. Not the easiest to replace use a needle nose pliers and patience.
/ 5525 Hand Throttle #4
The nut that ties the cable to the throttle on the engine could gave come off... This happed to a 6025 I had....
Thanks for the help. It will probably be this weekend before I can get out there to figure it out.
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2019 Ford F-550 Altec AT248F 43ft. Bucket Truck (A64556)
2019 Ford F-550...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
MAN BASKET (A64553)
MAN BASKET (A64553)
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
