5500 KMW Loader Pivot Pin
   / 5500 KMW Loader Pivot Pin #1
Mad Mac
Grapeland, TX
Mahindra 5555
The Mahindra 1 x 4-1/8" pin is hollow and after only ten years of abuse sheared off on one side. It is the upper pin in this picture with the locking ear tab. Any economical substitutes? Thank you for your attention to this matter.
I forgot the picture.
AP1GczN5znWEfd0LfuoSvOsARw97RrZkHe7WRh4n9jneClAgBUU2bzjIR0LljvCKOOi-ZF7s1gYoLAEzXItBuAiZdRQYTKt3KoUT8L9VdtRALx4LSDrAPAVg=w2400
Note that the upper pin that sheared off is hollow, but the lower pin is solid. The pin out of frame bottom right is same as top pin. Wouldn't solid be better?
   / 5500 KMW Loader Pivot Pin #3
By hollow, do you mean drilled down the center for grease? Some of mine on the 7520 are. Greased from the end to exit at a circle groove midway down the pin. On mine the pins fatigue and break at that groove.
They are like a piece of pipe. I can stick my finger in the broken off end.
   / 5500 KMW Loader Pivot Pin #5
Hmm - sounds stupid. I would look into substituting that adjacent solid pin replacement part for the failed hollow part. Just make sure you provide for greasing the pivot.
Thank you. I think you are right.
   / 5500 KMW Loader Pivot Pin #7
Mac, is that top pin greaseable? It doesn't appear to be. So it would be the same situation as the bottom pin just out of frame which I assume holds the lift hydraulics.
Joe
   / 5500 KMW Loader Pivot Pin #9
I think I’d take a look at the rest of the hollow pins and replace with solid, good chance more are ready to let go . Do all 4 of the loader cylinders use hollow pins at both ends?
It looks like only the four pins
at the attachment plates on the tractor.
The ones in front appear to be different.
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
White Loader (A50775)
2020 SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A52705)
2020 SELLICK...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55788)
2021 Chevrolet...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2010 Ford Fusion Sedan (A55758)
2010 Ford Fusion...
