5500 KMW Loader Pivot Pin
/ 5500 KMW Loader Pivot Pin #1
Mad Mac
Gold Member
Grapeland, TX
Mahindra 5555
The Mahindra 1 x 4-1/8" pin is hollow and after only ten years of abuse sheared off on one side. It is the upper pin in this picture with the locking ear tab. Any economical substitutes? Thank you for your attention to this matter.
I forgot the picture.
AP1GczN5znWEfd0LfuoSvOsARw97RrZkHe7WRh4n9jneClAgBUU2bzjIR0LljvCKOOi-ZF7s1gYoLAEzXItBuAiZdRQYTKt3KoUT8L9VdtRALx4LSDrAPAVg=w2400
Note that the upper pin that sheared off is hollow, but the lower pin is solid. The pin out of frame bottom right is same as top pin. Wouldn't solid be better?
/ 5500 KMW Loader Pivot Pin #3
By hollow, do you mean drilled down the center for grease? Some of mine on the 7520 are. Greased from the end to exit at a circle groove midway down the pin. On mine the pins fatigue and break at that groove.
They are like a piece of pipe. I can stick my finger in the broken off end.
/ 5500 KMW Loader Pivot Pin #5
Hmm - sounds stupid. I would look into substituting that adjacent solid pin replacement part for the failed hollow part. Just make sure you provide for greasing the pivot.
Thank you. I think you are right.
/ 5500 KMW Loader Pivot Pin #7
Mac, is that top pin greaseable? It doesn't appear to be. So it would be the same situation as the bottom pin just out of frame which I assume holds the lift hydraulics.
Joe
/ 5500 KMW Loader Pivot Pin #9
I think I’d take a look at the rest of the hollow pins and replace with solid, good chance more are ready to let go . Do all 4 of the loader cylinders use hollow pins at both ends?
It looks like only the four pins
at the attachment plates on the tractor.
The ones in front appear to be different.
It lasted 10 years. I'm just going to cave and rush order one from my dealer.
2002 John Deere 4510 Tractor (A64047)
2002 John Deere...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2023 Case TV450B (A62177)
2023 Case TV450B...
FERGUSON 21 (2) ROW PLANTER (A62130)
FERGUSON 21 (2)...
2019 Ram 4500 4x4 S/A Dump Truck (A61568)
2019 Ram 4500 4x4...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
