5500 discontinued??
/ 5500 discontinued?? #1
cvray
Talked to local dealer near Memphis Tennesse and they told me the 5500 has been discontinued and essentially replaced by the 5530 and 5520. I havent seen anything about this anywhere else and even the mahindrausa website still lists this as an active model. Anyone have any information?
/ 5500 discontinued?? #2
As far as I know the 30 series is replacing the 00 series 4wd only. You should still be able to get the 5500 in 2wd model if that's what you want. If you want the 4wd you will need to go to the 20 or 30 series.
/ 5500 discontinued?? #3
yes, the 00 series 4wd's are being discontinued....they will now be included into the 30 series. There are a few changes in the models most of it being just the layout of the controls. The 20 series are a totally different unit, much heavier and robust that the 30 series.
thanks, Evan
Thanks..it will be 4wd..I got a quote on the 5520 4wd with loader for around23500 and the 5530 4wd/loader for 22500..I had a quote on the 5500 4wd/loader at 21500.
/ 5500 discontinued?? #5
Yup, you guys are right. I bought my 4500 4WD in 2004. It was replaced, I believe, in 2005 by the 4530.
/ 5500 discontinued?? #6
Be sure that you sit on both of those before you buy.
/ 5500 discontinued?? #7
I have had my 6520 for almost a year now.:D Since then I have checked out a 4530 and a 5530 and love the layout and the "feel" of both.:) But they are nothing compared to a 20 series.
hugs, Brandi
/ 5500 discontinued?? #8
I'd sure like to have the 4 more gears on my 6000. Other than that I wouldn't change a thing that they haven't already changed on the 30 series.
I probably wouldn't use the extra gears for anything other than tilling, but they would be nice to have.
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
Danuser 3Pt Post Driver (A66408)
Danuser 3Pt Post...
2022 EZ-GO ELITE...
2007 Ford Fusion Sedan (A64557)
2007 Ford Fusion...
