5425 neutral light issue
/ 5425 neutral light issue #1
Onebrock
John Deere 5425
My 2007 5425 has developed an annoying issue. When I start it the 4 wheel drive light shows on the dash, no neutral light. With no neutral light the tractor won稚 move. The 4 wheel drive switch is not turned on. After 2 to 5 minutes the 4 wheel drive light goes out an neutral light comes on and everything is good to go. It must have something to do with a solenoid. I have talked to several John Deere dealers and non have a clue. Any help would be appreciated.
/ 5425 neutral light issue #2
:welcome: to TBN
That does sound annoying.. wish I had some knowledge to trouble shoot that, but alas none. Hope you get some ideas from others soon.
/ 5425 neutral light issue #3
Sticking neutral sensor?
Bad 4wd switch?
Bad ground somewhere?
Just throwing out ideas.
Does tractor have to be in neutral to start?
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2021 JCB 35Z-1 Mini Excavator (A61572)
2021 JCB 35Z-1...
2013 FORD F250 (A60460)
2013 FORD F250...
2017 Ford Expedition SUV (A61574)
2017 Ford...
20800 (A56859)
20800 (A56859)
