5420 pto
/ 5420 pto #1
hwy65mx
john deere 5420
1050 hours pto slips under heavy load while tilling.
lookslike the cable is adjusted all the way in. no free play left
/ 5420 pto #3
Perhaps you might post your thread in the John Deere forum here on TBN. In this way, you will be more apt to receive more replies. BTW, Welcome Aboard and Good Luck.:tractor:
/ 5420 pto #4
Along with taking Creekbends suggestion.
What type/size of tiller are you using and type of PTO shaft does is it use a slip-clutch or shear pin and does it appear to be working?
/ 5420 pto #5
Welcome to TBN; what creekbend and JD5210 said.
/ 5420 pto #8
Have you determined if the PTO is slipping in the tractor or a slip clutch on the implement?
I think the PTO clutch lever/cable/linkage is adjusted with the PTO disengaged.
Is traction clutch properly adjusted? Assuming it's a dry clutch..
/ 5420 pto #9
Zebra might be right, I have 4400 hours on my 5420 and it used to till around 3000 hours with my Terranova (Green Maschio) /Maschio C205. It never slipped. I think it would be the shaft. I would tighten it tight as you cant but not super tight that its seized.
/ 5420 pto
wet clutch. tiller is massive 80" wide. wieghs 1950 lbs. shaft actually stopped moving so that elimated shaft clutch. after trip to dealership and a pto dyno test a new cable was installed service manager said they have had some problems them them stretching. have used it all summer no problems
John Deere Lift Arms (A65640)
John Deere Lift...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
1992 GMC Top Kick Fuel Truck (A62679)
1992 GMC Top Kick...
New Holland 675 Manure Spreader (A66408)
New Holland 675...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2016 EZ-GO GAS GOLF CART (A63276)
2016 EZ-GO GAS...
